Water pump replacement WIS documents
Old Nov 21, 2011 | 06:51 PM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
I have had several requests for water pump replacement documents, so I figured I would attach the most popular ones to this thread.
Old Nov 21, 2011 | 09:39 PM
ND2020's Avatar
2004 C320 Sport
Thanks for taking the time John. Much appreciated!
Old Nov 21, 2011 | 09:42 PM
johnand's Avatar
Super Moderator
No problem. Sorry it took a little longer than I said it would. Been a crazy week. Glad I could help. Good luck with the repair.
Old Nov 21, 2011 | 10:34 PM
ND2020's Avatar
2004 C320 Sport
No worries. I was putting it off as long as I could, but today I sprung a leak somewhere (yet to be determined). My pulley has been wobbling for a week or so and it sounds awful. Looks like I'll be doing it over the holiday.
Old Mar 15, 2012 | 10:47 PM
jcmajewski's Avatar
c320 & c350
Thanks for the docs - you're a life saver!
Old Sep 13, 2022 | 05:03 PM
Jerry Easley's Avatar
'00 CLK320, '01 ML320 Designo, '01 ML320 Sport; '04 CLK320 Coupe Avantgar; '04 C230 SportCoupe (HB)
Just a note to say - in Sep 2022 - this Nov 2011 post with the Water Pump ML WIS R&I was very helpful
Old Sep 20, 2022 | 08:30 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Gack! M112 water pump! Did it blind.Just started taking **** apart. No docs.
Paid local shop an arm and a leg for the pump, but it paid off,
they answered questions and loaned me the special tools for getting the
fan off (99 ML320).
BEST PIECE OF ADVISE THEY GAVE! IMPORTANT!
sketch around the pump and pump gasket and holes on a piece of cardboard and
make holes for the bolts in the cardboard, THEY'RE ALL DIFFERENT lengths!
Put the bolts in the holes as you remove them so you know where they go on reassembly,
because other wise you can CRACK the timing cover if you put the wrong bolt in the wrong place.
