brake question
Old Dec 1, 2011 | 10:10 PM
JFarhanbod's Avatar
2003 C230K Sedan
brake question
so i need new front brakes and i went onto rmeuropean.com to pick some up but they have 2 different kinds, 1 for cars with the sport and 1 for regular. my car is an 03 c230 and according to a member here who ran my vmi my car is a sport/aventgarde package but the rotors on my car right now arent drilled (the sports on rmeuro are) so which do i pick up? thanks
Old Dec 1, 2011 | 11:00 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
if u go on autohausaz.com u will find the parts u need
Old Dec 1, 2011 | 11:13 PM
e1000's Avatar
a quarter mile at a time
AFAIK, all 03's have the regular, non-sport brakes.
Old Dec 2, 2011 | 05:13 AM
Glyn M Ruck's Avatar
Super Moderator
+1 ^
Old Dec 2, 2011 | 05:53 AM
why do they have amg brake pads for this car on autohauz then?
Old Dec 2, 2011 | 05:56 AM
JFarhanbod's Avatar
2003 C230K Sedan
what is the 949 203.040 sport package they are talking about then?
Old Dec 2, 2011 | 07:02 AM
Super Moderator
2003 models had the standard sliding caliper & non drilled discs. This is ROW information Then the US had a thing called the 2004.5 which was a sort of hybrid. US only got the full facelift in 2005. ROW & SA got the full facelift in March 2004. Sport Pack in ROW as of March 2004 had the larger Brembo drilled rotors/discs & the fancy calipers with "Mercedes Benz" on them. Your car sounds as though it was pre brake upgrade but you had better have a very close look at P/N's.
Old Dec 2, 2011 | 10:54 AM
Keithb's Avatar
2020 A35, @021 F250, 96 Mustang
I'm looking at replacing brakes (and calipers) front and back on my C320 Sport Coupe. What are the differences between the stock brakes I have and the C32 for 2003? Am i correct in thinking I have the 300mm front 290mm rear rotors on a C320SC? I have the 17" Evolution wheels if that helps. TIA
Old Dec 2, 2011 | 11:51 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Can you post a photo? The C320 coupe from 2003 should have standard, single piston sliding calipers and non-drilled rotors. The C32 had four-piston fixed calipers made by Brembo, and large cross-drilled rotors.
Old Dec 3, 2011 | 08:28 AM
Keithb's Avatar
So, here's what I have on the car. I think they are the reg 300mm sliding front and 290mm single piston rear. (excuse the rust, haven't had the car out for a couple of weeks.)
So, would the C32 calipers with some non-oem 345mm front and 300mm rear rotors be a good bang for buck replacement? The C32 calipers are 4 piston front and 2 rear iirc? TIA
Attached Thumbnails brake question-c320front.jpg   brake question-c320rear.jpg
Old Dec 3, 2011 | 10:19 AM
sheet my c230 front caliper is way bigger
and my rear is double ur rear size
hense the 2005 model
Old Dec 3, 2011 | 03:10 PM
phister's Avatar
06 C230 SS 6spd
you can either go with C32 brake setup, or if you want to save some $$$ you can always look into the 05+ C230 (2 piston) or the C350 sport calipers, the C350 have 4 piston if I recall correctly.
Old Dec 4, 2011 | 10:22 AM
Keithb's Avatar
Are the 03 C32 rear calipers the same as what I have? I see some places seem to sell the same calipers for all 03 models. Confusing... Are the 05+ C350s a direct bolt on? TIA
