can someone help me? What is this, and how do I get one?
2018 E400 4Matic Coupe
Hello all, I'm usually a watcher, and not a "poster". The picture is of a 2005 C230 Kompressor motor. The part that's in the box (sorry, hard to see) is missing on my car. What is it and where do I get one? If you can't see the box, it's on the left side of the main engine cover, there are two red "breathers", I'm missing the one on the left.
Thank you to anyone that helps me!!!!!!!!!!!!!!
2012 C300 4Matic
Edit: Moved to W203 forum!
The cover inside the box is for the transmission fill tube. The cover is used to "seal" the transmission. It has a tab that must be broken when it is removed. You should keep it covered. A new cover is inexpensive.
The other red cover outside the box in the picture is the oil extraction tube. Use this to vacuum the oil from the crankcase when changing oil.
2006 C230 Sedan
