MCS-II gps & antenna
The nav never showed any number for satellite signals received, so I suspect a bad GPS antenna.
The unit has not yet been "encoded" by an SDS so that the instrument cluster shows nav data because of this problem.
The antenna sold to me with the unit is a generic blue-connector FAKRA one, I think. It is labeled "GPS Antenna G-503".
A few questions to the gurus on post-facelift W203 US COMAND:
- Is the only way to tell if the antenna is bad by getting another antenna?
- Does the fact that I measure 0.005 ohms between the center and shield of the FAKRA GPS antenna connector mean anything?
(Well, I know it means the antenna wire isn't broken, but I don't know what resistance this is supposed to be.)
- What is the correct antenna for this unit?
(I've seen a lot of posts on this, but many reference APS units, not MCS-II, and/or have links to long-expired eBay items).
You can use the EPC to find the correct replacement antenna for your car.
The information that a passive antenna should read a very high resistance value (infinite or close to it, depending on the meter) is a very valuable input - thanks.
Fyi, I checked my copy of the EPC and all I get is the OEM rear-mounted GPS/Telaid antenna, and I'm interested in an under dash-mount retrofit one that is confirmed compatible with the MCS-II Comand units (OEM pn? Is it the same as the APS one?) or an aftermarket one that will definitely work with my MCS-II.
Oh, and your signature line mentions "no snickering" - Hey, member "jrthiele" showed us how good a W203 wagon can look with a CL-type grille awhile ago (11/27/07)!
Probably because the prev. owner had the antenna wire in a place where it was baked by the sun, the wire insulation was very fragile.
This generic antenna doesn't like going under the dash top - # of satellites goes down.
Can anyone tell me if the M-B retrofit part, M-B part number 67823100 (which supersedes 2038200975), has a FAKRA connector, or needs a connector adapter?
