Transmission fluid question
Old Dec 17, 2011 | 02:38 AM
a3i's Avatar
a3i
2005 Mercedes C230
I replaced my transmission plug after it had a leak, put back the amount of fluid that I lost when I dropped the pan and did a reading with the dipstick and I need to add more. Ive used OEM fluid so far but my question is, can I top it off with the Valvoline Maxlife ATF, which according to Valvoline is compatible with my 772.6 automatic transmission. Is it safe to mix it with the current OEM fluid thats in there now? I think Im only about half a quart short
Old Dec 17, 2011 | 04:12 AM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I would not use Valvoline as it is not on the list of MB approved oils.
Try Ryder Fleet Products.Its cheap enough.http://www.ryderfleetproducts.com/ry...llSentence=yes
Please see list below :-
236.14 Automatic transmission fluids (ATF, Specification 236.14)
Application in vehicles/major assemblies refer to Sheet 231.1
Overview
Last update: 12/05/2011
PRODUCTNAME
PRINCIPAL
Fuchs TITAN ATF 4134
Fuchs Petrolub AG, Mannheim/Deutschland
MB 236.14 ATF NAG2VSport A 001 989 68 03
Daimler AG, Stuttgart/Deutschland
Mercedes-Benz Automatik-Getriebeöl Blatt 236.14
Mobil ATF 134
Exxon Mobil Corporation, FAIRFAX, Virginia/USA
OMV ATF M plus
OMV Refining & Marketing GmbH, VIENNA/Österreich
Q8 AUTO 25
Kuwait National Petroleum Company, Kuwait/KUWAIT
Shell ATF134
Shell International Petroleum Company, LONDON/UNITED KINGDOM
Shell SPIRAX S6 ATF 134M
TUTELA TRANSMISSION STARFLUID 7S
PETRONAS LUBRICANTS INTERNATIONAL, KUALA LAMPUR/MALAYSIA
Old Dec 17, 2011 | 05:07 AM
Glyn M Ruck's Avatar
Super Moderator
See here - same applies to the 722.6 transmission just easier to top up with a dipstick tube.
All approved 236.14 fluids are fungible. It's part of the testing regime for approval. Do not use non approved fluids.
https://mbworld.org/forums/c-class-w...nsmission.html
