Nice rims but I don't know if they fit (19s)
'97 S600, '93 300SE, '98 CL500, '04 S320, '07 525D
![Talking](https://mbworld.org/forums/images/icons/icon10.gif)
http://www.ebay.co.uk/itm/19-MERCEDE...item35b7a8d287
I found these rims on Ebay and i really want them but i'm not sure if it will fit.
I want to run 275\30\19 rear and 235\35\19 front.
Do you think they will be ok for my car , not rubbing or anything, this is the most important?![bow](https://mbworld.org/forums/images/smilies/bowdown.gif)
Thanks!
Thanks!
2013 ML350
I see they are a 38mm offset and 8.5" wide. Do you have big brakes up front? If so the wheel may rub on calipers/strut tower and you may need to run a 5mm spacer... that's kind right at the offset where clearance in that area is of concern....
If you have the sportpack brakes you need to test fit them first. Because even with a perfect ET value it's possible that the spokes of the wheel will hit the brake caliper.
I don't have sportbrakes, i finally went for some 19s, ET35 on 8J all four. They are ok, i tested them yesterday and everything fits.
Thanks a lot guys.
Thanks a lot guys.
