2006 c350 ECU question
Old Jan 7, 2012 | 09:33 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Does the C350 have a obd2 port? I have heard different stories..
Old Jan 7, 2012 | 10:17 PM
TexFinn's Avatar
10 Tahoe LT, 07 Silverado Z71, 99 BMW R1100RT
AFAIK it does. However, the reader needs to be CANBUS compatible.
Old Jan 7, 2012 | 10:20 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Ok. I was talking to a tuner and he said it doesnt have a obd2? That is going to make tuning a pain!
Old Jan 7, 2012 | 10:58 PM
TexFinn's Avatar
All cars sold in the US after 1/1/96 are required to have OBD 2. I'd be a bit wary about a tuner telling you your car doesn't have one.
Old Jan 7, 2012 | 11:10 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Thats what im saying. Im not going to give out the name but its a very well known trusted tuning company. I have went to them before for tuning.
Old Jan 7, 2012 | 11:30 PM
samaritrey's Avatar
Super Moderator
THE C350
It could be that they mean it is not compatible for OBD 2 turning. Some cars can't be tuned over OBD 2 and you have to ship the ecu off to get tuned.
Old Jan 7, 2012 | 11:37 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
Originally Posted by TexFinn
All cars sold in the US after 1/1/96 are required to have OBD 2. I'd be a bit wary about a tuner telling you your car doesn't have one. :report:
+1
Any so-called “tuner” dispensing faulty intel like that certainly doesn’t deserve your business.
Note most (later version) MB ECU/TCU/EGSs must be removed from the vehicle in order to facilitate aftermarket hacking. ;)
Old Jan 7, 2012 | 11:41 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Well say I was going to get a custom tune done for a turbo or a throttle body how would that work? They would guess and than constantly shipping my ecu back and forth...
Old Jan 8, 2012 | 10:33 AM
MBfinatic's Avatar
e36 318i, 2004 sti
Yeah I hope it was just a simple mistake.. That will deff DELAY my plans.
Old Jan 8, 2012 | 07:22 PM
e1000's Avatar
a quarter mile at a time
The 2006 C350 absolutely has an OBD2 port.
The OBD2 port cannot be used to flash a new tune to the ECU.
IMO, many popular tuning companies are absolutely, positively NOT trustworthy, especially some that are often mentioned here.
Old Jan 8, 2012 | 10:02 PM
MBfinatic's Avatar
e36 318i, 2004 sti
It does have it! It sending the ecu in for tuning.. Any way around that?
Old Jan 9, 2012 | 03:45 AM
e1000's Avatar
did you even read my post?
Old Jan 9, 2012 | 04:46 AM
W203E35's Avatar
2006 C350 Sport 6MT
Hey guys, long time no talk. Happy New Year! Hope all is well with everyone.
I believe your tuner wasn't saying you don't have an OBDII but rather your car can not be tuned through OBDII. From what I hear the tuners can unlock this and then it can be done through the OBDII. Mine was never done and was always done through BDM. I know the older models can be tuned through the OBDII.
With your C350 and/or the modern ECU tuning is done through BDM.
Here is how the process looks.
They read and write to files/maps with a BDM chip reading tool and they use software like winols to tune it.
Here is how the winols software and maps look like.
This company makes the software and it's pretty pricey. http://www.evc.de/en/
Some other useful information:
They do have BDM flash tools on ebay (http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313) and I'm sure you can find winols online somewhere but don't think if you have all this you're gonna start modding your car.
The important thing here is something called DAMOS. What are DAMOS you ask? DAMOS are special files. For example you get BDM hardware and you somehow get the software and you hook your ECU up to it don't think you're going to easily be able to find the correct maps.
You're going to get over a hundred maps and will be scratching your head. But with DAMOS files everything is labeled. So you know for example the first map is the o2 map. The second map is the injector cycle and so on (these are just examples) by the way these are all in German....google translate?
Now your average tuner (not speaking from experience and not speaking from any tuner/tuners here at MBWorld) will have the DAMOS files. You'll go to him and he'll copy your files he'll move couple of maps here and there and sometimes increase something all across the map 5% or 10% or even if it's dangerous he or she might even say "ohh well the knock sensors will take care of it". From what I heard..word on the underground tuning world is they acquire these damos files from a source. There are always accusations that this tuner stole this other tuners files or it's the same code as mine and even both tuners had the same error on the map and that's most likely they got the damos files from the same source and it's because of that...who know what really goes on.
Is your tuner going to tune your car through OBDII? Can he enable this? If not then tuning this will be a female dog. Unless it's someone who has already done this. Can you imagine taking ECU out hooking up to BDM and then putting it back. Running the car. Taking it out back on bdm and tuning files then back on car and so on.
What I would recommend is if you can talk to someone knowledgeable enough that can guide you more towards maybe a piggyback of some sort. Atleast with a piggyback you are not stuck with 1 tuner and I believe are able to fine tune more.
A lot of questions you have to ask this tuner before going with it. What will happen with my car if the climate is hot? How safe is the tune? Are you relying on just the knock sensors (YOU"LL BE VERY SURPRISED ON THIS ONE!)?
Good Luck, I hope everything works out to the best.
Old Jan 11, 2012 | 03:51 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Wow a lot of info. Your the man! Now Im still a little confused on how a piggyback works and were to get one..
Old Jan 13, 2012 | 10:06 AM
MBfinatic's Avatar
e36 318i, 2004 sti
Than how do they re flash the 2006 c230? Isnt that the same m272 motor just different displacement? So it would be the same ECU?
Old Jan 14, 2012 | 09:23 PM
vdemon311's Avatar
2006 c230
....You remove and send in your ECU to the company just as stated above... eurocharged does this as well as a few others
Old Jan 14, 2012 | 09:28 PM
vdemon311's Avatar
2006 c230
...no piggybacks for the w203..
Old Jan 14, 2012 | 10:15 PM
W203E35's Avatar
2006 C350 Sport 6MT
Piggyback would only be for if you go for the turbo option. Although your ECU ME9.7 can handle boost but it'll be a lot easier with a piggyback.
Here is a pretty good one. AEM Fuel Ignition Controller 6 http://www.aemelectronics.com/engine...oller-f-ic-12/
If you can get a hold of Max Hughes he can help you. He went MIA. He is on mymb and mbworld with the handle Max Hughes. Also he mentioned the AEM FIC 8 was way easier and a lot more options to work with than the AEM FIC 6. I'm sure if you talk to other tuners they can maybe help you out with a piggyback of some sort.
http://www.youtube.com/watch?v=NCXHqXFdGJo
Good Luck
Old Jan 15, 2012 | 04:59 PM
MBfinatic's Avatar
e36 318i, 2004 sti
Good Luck
Does the AEM FIC 6 work with this car easily? I am clueless on this particular stuff..
