Cold start issue - battery?
Old Jan 21, 2012 | 04:15 PM
chmura's Avatar
2007 C230
So my car has been standing outside in the freezing winter for about 3 days without being driven. Yesterday I had to move it on a side street because of a snow storm, did that no problem. Later that night I went back started it and it made the noise you see in the video below from the muffler for about two minutes and went back to normal, I haven't driven it. Today I came back started her up again, it did have trouble starting, possibly low battery. After being started it shut off a moment later and wouldn't start again.
Is it the battery or some other issue here?
http://www.youtube.com/watch?v=egKvFhbaZag
Old Jan 21, 2012 | 05:29 PM
Glyn M Ruck's Avatar
Super Moderator
Does it try to crank at all? Do the lights dim badly while cranking?
You could have a low battery. Cold can cause a battery to fail.
Check fuse 52 in the front SAM if there is zero crank. It's under value at 15 amps - replace with 20 amp. This is the most common failure
In fact check fuses 31, 52 & 57 while you are about it. All three are required to enable start but 52 usually blows.
If battery & fuses are OK you need to check CPS & temperature sensor. They are also interrogated to enable start.
Old Jan 21, 2012 | 09:01 PM
chmura's Avatar
2007 C230
As always a detailed response by Glyn
I haven't got a chance to check on any fuses, but after getting a jump it's been starting smoothly ever since; just like summer time.
The cold must have got to it and I will probably need to replace the battery if I have a problem with this again, I'll see how it does after tonight.
Old Jan 21, 2012 | 09:50 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Did you get any malfunction messages on your instrument cluster? Are there any error codes? Do you have access to a scanner like Innova 3140 that display live data
Put it in dyno mode so you can observe voltage
- key out
- key in
- navigate instrument cluster to milage display
- hit reset buttome 3 times
What is voltage before start? Lowest voltage when cranking? Idle voltage? Voltage when car is reving at about 1800 RPM?
Old Jan 22, 2012 | 06:05 AM
Super Moderator
And have the battery load tested!
