Is there a guide to replacing door handle IR sensors?
Tony I can send you a replacement that is already repaired and tested in exchange for your repairable non-functioning one. I will be in touch shortly.
the IR sensor on my 04 c230K
If anyone is interested, I have spare door sensors for both drivers and passenger door.
I'll be doing the 'fix', and testing on my vehicle.
If you don't feel comfortable soldering,
I can sell a repaired one, that's tested in a vehicle, with exchange,
for a fee of course.
Yes I would be interested, Where are you located? if Mailed, where do I mail it. For privacy, you can respond to my email at chiro75@aol.com Thank you Tony
Sorry been down with the flu...I'll be in touch soon.
I'll repair and test the sensor.
#32
c63 replica
#33
MERCEDES 2004 E 320, 2003 350 ml, 2004 c230 kompressor
Can you be a bit more specific, did you still have to heat and cool the joints of the part you bought on eBay?
#34
#36
wanderlust360 (05-23-2018)
#37
2003 C230K Coupe Orion Blue
2003 has both driver's and passenger's sides. Not sure about the later models.
And yes, both of mine have gone bad over the years. Passenger one was fixed under warranty though.
#38
This part number is A2037602377. It includes IR sensor and mechanical lock for only your keys. W/o DIY you can get it only from Mercedes service after typical anti-thief formality. If you can work with solder iron, then remove this part from car's door and replace or repair IR sensor. All you need is torx20. Unscrew one torx20 screw in inner door side deep hole under door's rubber and remove part carefully. It connects to door's control module with 3-pin connector. Then you must cut metallic tooth for IR sensor removing. Now you can try to repair IR sensor. Carefully remove transparent mastic near outer red sensor's window and solder with care two sensor's pin on PCB. Then connect sensor and check it's work. If sensor is working you can fix it on the part with nylon strip. Otherwise you can replace one by any 36kHz 3-pin IR receiver from TV remote control like TSOP1736. In car side connector: green wire is Ground, brown wire +5V, white wire Data.
Thank you
#39
Door IR sensor
#41
Jim Barber (08-15-2019)
#42
My Summer Convenience Feature has stopped working. You can reach me directly at: jpbarber01@gmail.com
#43
Planning to make this repair soon
I scavenged some audio components from another C230 today and I also picked up the sensor. This will allow for some practice before I work on the one in my car.
#44
I finished the repair today. Thanks for sharing the repair process. I repaired the one I scavenged as a test and then repaired the one in my car. Now I have an extra working sensor. If anyone needs one, send me a PM. I have $15 invested in it.
#45
Seems like my driver side IR is dead as I can only lock/unlock the car with both remotes when aiming at the passenger side IR only now.
many thanks if you can help out or provide guidance on who might, since I’m not comfortable performing this task..
#46
IR sensor roll pin remove without cut or drill
You can remove the roll pins without cut the holders or drill out. Just need to use a small screw (about 1mm) and drive into the roll pin. Then you can pull out, and you can insert back after fixing the receiver.
