2002 C240 Exterior Temperature Sensor
Old Feb 13, 2012 | 06:37 PM
umolina's Avatar
2002 c240 Elegance
Does any know if changing the Temperature sensor is DIY, or do I need to go to the shop? I have read older threads, and they all say that you can pull the mesh of off the fog light. This is not the case, mine if pretty fixed, and I have a cover over the whole section underneath, so unless I unscrew this protective cover and reach in from behind, I dont see this happening. Thanks!
Old Feb 13, 2012 | 10:32 PM
contact148's Avatar
2003 c240 4matic wagon
if its the same as my 2003 then you need to remove the lower cover only like 2 screws and one or two plactic clip things then the sensor just pulls unclips very easy to do
Old Feb 14, 2012 | 08:31 AM
Glyn M Ruck's Avatar
Super Moderator
It's the same.
Old Feb 14, 2012 | 09:52 AM
umolina's Avatar
2002 c240 Elegance
Thank you for your responses, I will unscrew the protective case. Thank you again.
