C230k limp mode w/ NO CEL
MBNiko, what were you doing with the car in limp mode? Did a restart get it out of limp? The car is a machine and doesn't need rest from being worked. Although if you were doing donuts, be advised this can have costly consequences with the W203.
If it went into limp and no codes show up stored or current and because you were in dyno mode, I'd not stress too much just yet.
Dyno mode doesn't increase take off speed or make the car faster, though, so no need in using it. All it does is remove the safety nets you might need.
Your car is probably just fine.
It won't hurt to check your transmission oil level and see if you have the oil leak at the pilot bushing.
