Engine Light is on! 2007 C230
I have 92000 miles on it, and even though the light is on it still drives smooth and quick as it did when I bought it in Nov 2011. PLEASE HELP! A mechanic said it might be the cam shaft.
Do I need to buy that extra part?
Sorry I'm a noob.
I replaced my cam magnets around 70-75k or so and it took care of CEL. No way to know for sure without the code, but if you know that you haven't replaced the magnets, then you might as well go ahead and do it. There are 4 of them total, about $20 a piece, and very very easy to replace yourself.
I'll find you a part # if you want and I can explain where they are and how to replace them.
Don't worry - you'll get your money's worth, since you'll be using it fairly frequently.
http://www.amazon.com/Equus-3130-Dia.../dp/B000KID31K
$127 for this is cheap, here in Toronto this unit goes for $299
and as Tommy said, yes you will be using often down the road as our cars love to throw CEL
EDIT
C230 Mulac helped out "Part # is A 272 051 01 77
You will need a total of 4. I bought mine from http://www.rmeuropean.com/
Let me know if you need some help replacing them. It's really easy. You just need to pop off the engine cover and there will be two on the right and two on the left. You'll need a torx rachet to unscrew them. Each one has 3 screws."
