NEED expert MB radio help!
1 Post
'06 Lexus GS300 RWD, '07 Camry SE V6 auto, '91 190E 2.6 auto
I took out my Audio CD 10 to sell, and replaced the stock tape deck. After I had the stock radio screwed in, I tested it by pressing the volume button/power button (the key was not in the ignition). The radio came on for several seconds and then went off, leaving the message "PROD" on the screen. I assume this means it wants the security code, which I don't know. Well, I put the key in and turned on the radio. The radio now seems to play without interuption, but when you turn the car off, the security LED on the radio no longer blinks, but the tow-away alarm LED does blink! WTF?!
Sorry to hear that Jim, MB's are troublesome cars and the dealers have lots and lots of experience dealing with such issues. They'll probably fix it under warranty.
1 Post
My MB is not "troublesome" and I didn't create this thread to give you another place to bash MB's. It's obvious "I" created this problem by tripping the security function in the radio.
1 Post
Some more info for anyone that may know how to "fix" this...
I remembered I may have left a CD in my Audio 10 CD, so I pulled out the stock deck again and re-connected the Audio 10 CD. I discovered that my wife must have removed my CD earlier, so I re-connected the stock radio. After I plugged it back up, the LED light on the radio started blinking as it should. I then inserted the key, turned it to position 1 and turned on the radio. It continued to play normal. After I turned off the car, the radio's LED didn't start blinking again. I pressed the door lock button on my remote and the LED on the tow-way alarm button began blinking again (the radio LED stayed off). I'm thinking that either I can enter the security code back into the system to get everything right, or the dealer will have to reset something. I'd much prefer to get it done myself
1 Post
2002 C230 Coupe
Did you say you swapped the 2 units when the battery was still connected? I think it is safe to do these things when the battery is disconnected so that you won't confuse the electric system.
So I think if you disconnect the battery, wait for a while, and then plug it back to let the system reinitiate it may solve your problem.
1 Post
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
1 Post
There is no radio code for these cars.
Administrator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
In some cases the VMI will list a code for the radio. But then again the CANBUS is supposed to recognise the radio. Someone on here posted something regarding the *PROD* readout a short while back. Might do a search.
1 Post
I did a search on PROD yesterday and discovered that once you get that signal, the radio is supposed to lock you out.
To recap: (1)I installed radio, but tested it before putting the dash piece back in (the little plug going to the area where the anti-tow button is was left disconnected during that time).
(2)I turned in on by pushing on the volume button with no key in the ignition.
(3)It would play for about 15 to 30 seconds and then stop and displayed PROD. You could press the volume and turn it on again, but it would only play for another 15-30 seconds before stopping again and displaying PROD again.
(4)Once, I inserted the key and went to position 1 or 2, I could turn on the radio and it played without interrruption and without displaying PROD.
(5) The only problem after that was that the security LED would no longer blink with the car off.
(6) And a possibly related problem is that with the car locked, the anti-tow button's LED blinks rapidly now.
(7) I disconnected tha battery for several seconds.
(8) Before turning on the car again, the LED on the radio would now blink as it should.
(9) I pressed the lock button on the remote and the anti-tow button started blinking too.
(10) I turned on the car - the radio came on and played normally - the anti-tow button goes off if you unlock the doors.
(11) ANOTHER issue upon starting the car after having the battery disconnected is that I'm getting an ESP error message on the MFD.
Apparently I've done something to really confuse this car's brain
1 Post
Jim, you can reset the ESP by turning the wheels fully to the right and then to the left.
1 Post
My tow alarm switch blinks too when I lock the doors.
![Confused](https://mbworld.org/forums/images/smilies/confused.gif)
It's normal.
Sorry, Jim - he's right; I wasn't thinking. Guess we all could have thought and calmed you down a little about the light blinking when the alarm's on.
1 Post
Guy's, I'm in a poor position to judge, but I don't think this is normal. The LED on my radio should blink when the car is off. It doesn't anymore since I switched back to the stock tape deck. Well, it did after I momentarily disconnected the battery, but as soon as I turned the car on, then off, it didn't start blinking as it should. The anti-tow button did start blinking after I locked the doors. I could SWEAR that I have never seen it blink before, or I could be completely wrong. I really do appreciate everyone's input into this though
2002 C230 K
Originally posted by Jim Banville
That's weird! I could have sworn the only blinking light in ny car was the radio's, and not the anti-tow button. If it was normal, I would have thought someone would have said so in one of the earlier responses
Funny aside, I just noticed within the last month that the anti-tow button light even blinks. At first I was "WTF?" but then decided that it was probably normal and I just never noticed.
- BT
1 Post
Okay people, so should both the radio's LED and the anti-tow blink when the car is off and locked? The rate that the anti-tow button blinks is much faster than the radio. Anti-tow is like 1 blink per second. Radio (when it was blinking) was like 1 blink every 3 seconds.
MB C230K
Confirmatory. The radio LED blinks whether you lock the car or not. The tow alarm light only blinks oce you have armed the alarm (lock the doors).
--Steffen
--Steffen
