My car getting slower... needs service?
I’ve been comparing my car with other C200s (sedan and coupes), yesterday I almost had to floor it to catch up with a C200 sedan that I really doubt its driver was pressing on the gas anyway near ¾ (I mean the driver stepped easy on the gas, wasn’t racing me or anything).
The car has 17900 miles on it (2600miles till service B).
I know about the gear adaptive thingy, and I believe that is not the issue.
Also something else… I drive my car for fun. Meaning… my foot is heavy on the gas. I always accelerate fast and things like that.
By the way, I changed the fuel filter about 4000 miles ago (I know, I didn’t have to). But I thought that might increase the car performance.
Thanks.
- BT
Forced-induction cars are perceptibly slower in hot weather. I've noticed that with our C 230 K in a recent heat wave. In the winter the car is a rocket. In the heat it is merely very quick.
I'd also suspect you put the fuel filter in backwards, or it's too restrictive for the car (Mercedes OEM part)? No fuel filter should need changing after a few thousand miles or km...unless you fill up at Billy Bob Bo-Dean's gas 'n go.
If the noticed loss of performance occured after replacing the new fuel filter than maybe something related to that is the problem (unless you replaced the filter because of the loss of performance).
- BT
well, the car was getting slow and thats why I changed it.
Is it really hot where you are?
and we get sand storms a lot during summer... that could effect the air filter I guess... right? well, I changed that too with the fuel filter.
and still... nothing changed.
weird? heh.
well... but still, that doesn't answer my question. heh.
I'm not compering my car with one driven in the UK... I'm compering it with other cars driven on the same street...
I'm not contesting that my car go from 0-60 in 11.5 seconds while the spec. said it can do 0-60 in 9.3 seconds.
what really bugs me is that its just slow that even an old galant or a really really old pick up truck take off faster than my car at traffic lights!
no, there is no problem in the compressor, they checked it at service A.
Cheers, BT
when someone say that, how fast do they mean?
cuz a couple of months ago I drove my car on the highway for a couple of days. I drove at speeds around 160 and 180Km/h. by the end of the week I got check coolant message and the car started to leak. I took it to the garage and they said that a pump (I think the one that pumps coolant) is broke and must be changed.
It costed me around 400 bucks...
So... how fast is fast?
Have you compared your car with other supercharged cars? You can't compare it with normally aspirated cars.
think....
Get some fuel injector cleaner and add 1 full bottle to a half tank of gas. Run it til the fuel warning appears on the MFD, then continue driving.
(why does this guy remind me of a certain Kuwati that was banned earlier this year?)
add i full bottle to a half tank of gas.
...but most of the people there are stupid, so... I should do it the same way you said it? half tank?
But you meant I should drive my car around till the warning appears and continue to drive? till when? and when should I refuel?
One last question if no one minds...
is it okay to switch between gas types every once in a while?
I want to use that fuel cleaner now, and use the ultra super gas and then after a while (couple of days or weeks) go back to the regular gas I used to use.
so?
For your comparison with the other C200K sedan, maybe this car's engine is still cold so I may be faster.
Yes, hot weather can make the car slower. The lag will be longer so it will take longer to reach the Kompressor "boiling" range ie. 2500-4500rpm. Once the Komp is boiling, there is not alot of difference.
every time I start my car in the early morning and drive it feels lighter and faster. but later when I leave college at noon (around 50C) the car feels heavier.
by the way... does that means if a C32 AMG sadan and a BMW M3 wanted to race in a hot weather, the M3 will win? It doesn't have a compressor, right?
