Need suspension Recommendation
Old Apr 23, 2012 | 04:18 AM
silvermamba's Avatar
2005 C230
I want to lower my car, but not to low. I don't want it low to a point where the car scrapes. What's the best suspension set up with a minimum drop.
Old Apr 23, 2012 | 08:28 AM
phister's Avatar
06 C230 SS 6spd
Eibach gives a good moderate proper drop still giving the car the factory angled stance.
Old Apr 23, 2012 | 12:51 PM
2005 C230
thanks suspension expert!
Old Apr 23, 2012 | 01:10 PM
2005 C230
What shocks do you recommend with the Eibachs?
What do you think o H&R Cup kit?
Old Apr 23, 2012 | 01:16 PM
2005 C230
what brand coilovers would you recommend with the option to adjust it to stock height or lowering it.
Old Apr 23, 2012 | 02:02 PM
niceguyftx's Avatar
2004.5 c230k
I have H&R coilovers and love it. Feels close to stock oem sports suspension. It's popular on here too.
Old Apr 23, 2012 | 04:32 PM
phister's Avatar
06 C230 SS 6spd
H&r cup kit is good because the struts and springs are designed to work together.
I love my BC, you can customize your spring rate, adjustable dampening, great range in height adjustment. I would only recommend coilovers if you plan on really adjusting your suspension quite a bit and really want to go low.
If you want a mild good drop go eibach or h&r cup kit. Koni are the struts/shocks I recommended. Gives you the ability to adjust dampening for ride comfort. most after market springs are stiffer so your ride will be a little bumpier so having the yellows adjustability for dampening will allow you soften it back to stock comfort almost.
Old Apr 29, 2012 | 02:17 AM
2005 C230
the eibach pro kit cost $250 and the koni sports cost $650. Should I just get coilovers instead? Are there any huge advantages with coilovers over springs and shocks?
Old Apr 29, 2012 | 04:14 AM
phister's Avatar
06 C230 SS 6spd
You can find the pro kit cheaper than that. Only advantage is adjustable height. But most c/o cost a couple more hundred then that and if you want adjustable dampening c/o it'll cost more. I would go with springs and koni yellows if you don't plan on adjusting your height that much
Old Apr 29, 2012 | 08:08 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
What phister said.
H&r cupkit is not gonna lower ur car if any.
