h i ds
Old Apr 29, 2012 | 09:05 PM
custom c280's Avatar
06 c280
h i ds
i have ddm tuning hids they freaking suck im on like my 4 or 5th pair threw warranty they cant seem to last more then sixs months i need a real hid company for my lights price is not and issue at this point just tired of sending back and forth
Old Apr 30, 2012 | 12:11 AM
Jay_Soprano's Avatar
06 w203 Blk/Blk - 06 w251 slv/blk
Haven't had any issues with mines, I have Mtec 4500k and they look stock bright white
Old Apr 30, 2012 | 12:44 AM
MIKESV8's Avatar
Aston Martin V8 Vantage
Use a company called houseofhid.com they're a great company with reliable products. Check out their website and give them a ring. Tell them michael with the c55 sent you.
Old Apr 30, 2012 | 10:10 AM
buklae620's Avatar
2005 MB C230K Sport Sedan & 2011 MB C300
I ordered a set from hidextra.com to put in my 05 c230k. The kit I had in their before was from aznoptics.com but with some customs issues regarding his products he may or may not have some kits in stock.
I took out the aznoptics kit and put it in my moms '11 c300 and now I'm running the hidextra.com kit. Everything seems to be working out fine so far. I've had the kit for about 3 weeks now. I have their 5000k set and the color output of the bulb is just a tad bit too blue for my taste. It's got a slight slight tint of blue to it.
My 5000k aznoptics kit was like a pure white color.
Old Apr 30, 2012 | 01:26 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
If price is not an issue, you should go with OEM Bi-Xenons or Depo bi-xenon replicas.
Old Apr 30, 2012 | 05:49 PM
Peydidy's Avatar
C63 AMG
I used hidextra.com too, my first set went out in a week but they replaced it for free, the set I am on know has lasted me a bit over 6 months and is still going strong
Old Apr 30, 2012 | 09:22 PM
samaritrey's Avatar
Super Moderator
THE C350
Originally Posted by LILBENZ230
If price is not an issue, you should go with OEM Bi-Xenons.
Fixed your post matt
Old May 1, 2012 | 01:25 AM
Moviela's Avatar
Here is a post I made from 2006. It still applies:
There are some questions you need to ask any one that sells kits to convert to HID lamps:
Is the conversion beam pattern correct?
How is the conversion made to be beam pattern correct?
How is the conversion tested to ensure beam pattern correctness?
If it is not beam pattern correct, can they tell you how to fix it?
Do they know what a correct beam pattern looks like?
Are they aware that non-beam pattern correct conversions have serious disadvantages? A person could get hurt!
I can't see how a bulb designed for a projector housing can be installed in a reflector housing and get a proper beam. Since the lamps must have their base changed, it might be possible. Mid 90's Mercedes actually had such a lamp, but it has fallen from favor. One big problem with putting a HID lamp in a reflector is the insulation of the return wire. Most reflectors are metalized, and will arc to the return wire.
The color temperature of the lamp is either 4300K or 6000K. Only 4300K is used in OEM headlights. How would you measure it? Knowing that most people can't, sellers lie. The way they make it blue is to put a filter on the external glass. This raises the color temperatue, but decreases the light output significantly.
My experience is that Osram (Sylvania) or Philips HID bulbs get more blue as they age, and they last about 2,000 hours. Asian lamps (unknown manufacturer) seem to remain rather constant in color, but expire at about 600 hours.
Conversion to Bi-Xenon is possible, but you must change the housings. MbenzNL.com has more infomation on factory parts. These lamps will probably not be available much longer because of the soon to start production of the new C class body style (W204), so you should move quickly if you really want them.
Changing the housings is not the full job. You do need the computer to be version coded for xenon lamps. This is because halogen lamps draw 55W and most HID lamps draw 35W. The car can tell the difference.
In most aftermarket installations you don't get the automatic leveling sensors and sensor wiring harness, nor the heated headlamp washers. Both of these require a lot of very expensive additional parts. Many folks don't think these items are really necessary, but be aware that Federal Motor Vehicle Safety Standard 108 requires the leveler and washer. It is your choice.
