how do i check for slop in rack?
Old Apr 30, 2012 | 10:59 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
im having my entire tie rods on both sides done tomarrow
can someone tell me how to check for slop in the rack?
i've looked everywhere cant find nothing about the rack
Old May 1, 2012 | 01:02 AM
Moviela's Avatar
Place your head between them, and shake back and forth vigorously while humming a monotone.
Boys, that is how you check a rack properly.
Old May 1, 2012 | 02:01 AM
glocati's Avatar
2016 GLE 350
Old May 1, 2012 | 11:45 AM
amanonfire's Avatar
W203
You're more likely to have bad bushings in the rack than a bad rack, as the rack bushings are a known weak point.
The way to check is to have someone under the car listening to where the knock is coming from as you turn the wheels. Otherwise its impossible to determine whether its an inner tie rod or the rack itself.
If you're having a shop do the work, then have them check.
Old May 1, 2012 | 05:19 PM
nlpamg's Avatar
Super Moderator Alumni
2019 GT3 RS, 2017 M3 30 Jahre
best response evar!
