Weird clanking noise from engine all of the sudden...
also wtf is that "Mercedes Case" for? lol
I'll post up info in the morning.
If you haven't done so, you can start pulling the valve cover, and spark plugs, and upper timing chain cover.
Don't forget, you will need some gasket maker for putting the upper cover back on.
http://www.autohausaz.com/search/pro...=W0133-1786813,
Theyre local too!
Good luck with the yard sale! those are always a ball of fun!
You shouldn't have to remove any fluids.
Your doing this a little different than me. I had the engine stripped down to the block. You do want to try not to move the cams too much.
When you're ready to break the chain, tie it off on either side to something with light gauge wire, string, or even small zip ties. That way when you cut/break it, it doesn't fall down into the engine.
Once cut, you can change out the guides if that's what you had planned.
EDIT: Now you can pull the alternator. There is a DIY in the stickies for it. Once out, there is a red plug in the block behind where the alt. was that you need to remove to access the tensioner. You can pop the plug out with a screw driver. You'll probably need a deep socket to get at the tensioner. I can't remember the size. Undo it and carefully remove from the block.
Install new tensioner and re install alternator and V belt.
Attach the end of the new chain to the end of the old one on the left side, with wire, or a zip tie as thou you are making one long chain.
Then use a 27mm socket to crank the engine counter clockwise on the crank pulley. This will feed the new chain around the crank sprocket.
Gotta run, that will get you started.
To insert the master link, you will need to put pressure on the tensioner so the chain is slack. You can also put wrenches on the cam sprockets to help "pull" the chain together, BUT, watch your timing marks, and be sure when the chain is together, that they are all lined up.
I'll post some pics in a little while.
727-687-6666
