Weird clanking noise from engine all of the sudden...
but now i need to know the part number so i can order another one...obviously its there because oil runs through there and through the tensioner...
just out of curiosity anyone know what owuld happen if the cams are slightly off on start up? i mean are we talking catostrophic, or is it something that will be very obvious at once but essentially not a big deal if shut down quickly
Since you've got the alternator off, you may want to take it to a local
Auto Electric shop if you have one (they're like a dying breed)
and have them do a rebuild on your alternator (typically 150-200), or at the very least throw some new brushes in there "while yer in there".
Typically an alternator will go out from the brushes wearing down to nubs sometime between 100K-150K miles.
Here's mine down to a nub at 120K, BEFORE it failed and left me stranded.
Mine will be a little different than yours, but same concept!
I also pulled my supercharger for rebuild too, but ended up finding one new for 600, sold the old one
for 250, 350 out of pocket. And a battery around that time, and belts, so no worries for the next 100K miles.
and no not started up yet...got the last parts from MB this morning, installing now and gonna bolt it all back up and throw some coolant in her and start her up...
started her up a second time to try and listen for it again, and let it sit for a bit longer this time, and then my idle began to settle down and the wobbling stopped and she steadied out at 800rpm and it was music to my ears...
although again, the noise at start up is still there...FML, my roommate is convinced it sounds like an suction thing, but i dont what that could even be, i have no opiniions on the matter anymore! lol
by the way, this wouldnt have anything to do with the fact that im not running it with an intake tube does it? mine broke apart when i was doing this project and i just havent gotten to the dealer yet to waste $50 on one yet...
anyone think this noise might have anything to do with my belt and supercharger? A buddy of mine suggested the belt might be just loose enough where the super isn't spinning up as fast as it should and is thus making a noise....cuz i noticed, i also get the rattle when the engine is cold and it is pulling a lot of power, aka when i let the clutch out a bit too early or something and the engine feels like its about to stall, the vibration/clank comes back then...but once warmed up it goes away...
i thought it might be a motor mount, but like i said it goes away...
what does the balancer chain do exactly?
