HELP My SRS Check Engine Light Came on =[
Old May 2, 2012 | 11:18 PM
speedoniphoto's Avatar
c230
HELP My SRS Check Engine Light Came on =[ It said malfunction something. the only thing I changed out was this:
Old May 2, 2012 | 11:23 PM
c230
it says "SRS system error go to workshop"
Old May 2, 2012 | 11:28 PM
Peydidy's Avatar
C63 AMG
What do you mean you changed out that? What did you put in place if it? I don't think that would be relevant to it though, SRS usually as to do with airbags, seat belts and such. Just saying that your SRS light came on won't really get you anywhere because there are a ton of things that could cause it. I would recommend buying a code reader and figuring out the code, then post the code here and go from there on what to do to fix it. Most likely you will need to go to the dealer though because I feel like I read somewhere on here that only the dealer can clear SRS codes. Not 100% sure about that though
Old May 2, 2012 | 11:31 PM
c230
I replaced it with the same OEM intake hose because the one I had was ripped.
Old May 2, 2012 | 11:32 PM
Peydidy's Avatar
C63 AMG
Well then I don't think it would be relevant, did it come on immediately after you changed it?
Old May 2, 2012 | 11:46 PM
c230
yeah right after i changed it, it happened. However my gf did spill soda around the passenger seat area..
Old May 2, 2012 | 11:54 PM
Peydidy's Avatar
C63 AMG
Probably you seatbealt then. I spilled water down there once and it threw on my srs light, dealer changed me 430 to replace it. The part itself is 80, it's the labor fees that kill you because they take the hole seat out
Old May 2, 2012 | 11:56 PM
c230
wow 430? this suckks!
Old May 3, 2012 | 12:00 AM
c230
what's a good code reader brand for mercedes?
Old May 3, 2012 | 12:03 AM
Peydidy's Avatar
C63 AMG
Im not to sure which is the best, I got myn at auto zone for $60 last week and its pretty good.
Old May 3, 2012 | 12:05 AM
Peydidy's Avatar
C63 AMG
If you can DIY it would be much cheeper just a $80 part, really nothings wrong, just a sensor issue because of the water (or in your case soda) damage. Again I am just assuming this may be your issue because it sounds very similar to myn it could be something else. SRS issues aren't something to play around with because it could have to do with something more dangerous like a airbag
Old May 3, 2012 | 12:21 AM
c230
thanks. Where do you plug in your obdII scanner into ?
Old May 3, 2012 | 12:30 AM
Peydidy's Avatar
C63 AMG
Sorta by the red Handel that you pull to pop your hood under the steering wheel. There's a plastic cover, you open that them plug in the reader there
Old May 3, 2012 | 12:53 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
that kind of scanner isnt going to read a srs codes
u need to go to a dealer or a shop that has dealer equipment
Old May 3, 2012 | 01:51 AM
c230
I looked up the recalls on the recalls government website and there was an airbag recall. However im thinking it's the seatbelt spill still, but not sure. The check engine light didnt come on until today and the spill happened over a week ago.
Old May 3, 2012 | 02:06 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Is your car 2005?
Old May 3, 2012 | 12:39 PM
c230
yeah it's an '05. ill probably stop by autozone. i heard they let you use their obII sensor. i ordered one on amazon already but im just curious...
Old May 3, 2012 | 01:18 PM
Peydidy's Avatar
C63 AMG
They don't anymore In California. They passed a law against stores like auto zone lending out there readers
Peydidy's Avatar
C63 AMG
They still will tell you what your code means though
Old May 3, 2012 | 05:52 PM
Leevan's Avatar
05 c230K
Originally Posted by C230 Sport Coup
Is your car 2005?
is an 05 more likely to have this? or is there an easy way to clear it? mine is an 05 and the SRS warning just came on while driving. nothing extreme, just cruising like 45 mph.
Old May 4, 2012 | 12:54 AM
c230
not sure but that's the recall for our year.
Old May 4, 2012 | 12:55 AM
c230
for some reason my check engine is not longer there and my srs sign is no longer there... weird. my obdii scanner is coming in tomorrow.
Old May 4, 2012 | 09:21 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
The check engine light and SRS light are not related.
Old May 4, 2012 | 09:42 AM
J.Christian's Avatar
(W203s) '04 C240, family member '05 C230 Kompressor
I had a problem last year with SRS lights... It turned out to be "bulletin" from MB where the connectors in the door sills were not staying connected with good contact. MB has a "retrofit" kit to fix it but my mechanic fixed it by hard soldering the wires. Check into this... If it happens enough to put out a bulletin then the timing could seem like it is connected to other things just by coincidence.
