Door Speaker
Old 05-10-2012, 03:15 AM
Eemo1's Avatar
2003 c180 Kompressor Sport
thanks again everyone.
i think i'll keep the stock 8" for now.
im going for the jbl's. prob put some dynamat stuff on the doors while im at it.
Old 05-10-2012, 03:26 AM
Moviela's Avatar
Originally Posted by Eemo1
Prob put some dynamat stuff in the doors while I'm at it.
It is only needed in the rear doors of a W203. The outside skin rattles a bit. Apply the material in the center of the panel. It does not need to cover all the way to the edges.
Old 05-10-2012, 03:34 AM
Eemo1's Avatar
so are you saying put some on the panel itself?
Old 05-10-2012, 09:40 AM
MIKESV8's Avatar
Aston Martin V8 Vantage
yea don't put another free air woofer in there, you'd be going backwards. and i have the material for very cheap if you want any, a kit specifically made for the doors.
Old 05-10-2012, 03:17 PM
grafittijunkie's Avatar
2004 C230K
Originally Posted by Moviela
The wire colors at the head unit are shown on the diagram. There are connectors between the headunit harness and the speakers in the door sill. The color code changes at that point.
You can mix and max manufacturers speakers and crossovers, but the specifications should be the same. When mixing manufacturers you need to be mindful of the phasing of the speakers. To test you can use a AA battery. Connect the + to the red or + on the speaker, the - to the other speaker terminal. Observe if the cone jumps in or out. All should be the same. If different change the polarity of the wires so all speakers move the same direction.
alright i just thought there was something wrong with the wiring of the speakers. will it sound weird if i mix and match crossovers, tweeters, and speakers?
Old 05-10-2012, 08:35 PM
efzauner's Avatar
2005 C240 2011 R350
Originally Posted by grafittijunkie
It's time for some new door speakers. Already have the head unit, just got to finish it up. I've done some research and got these sizes. Front door speaker size are 6.5 with 1.5 depth. the rear is 5.25 with 1.5 depth. has anyone fit after market speakers in their car? 1.5 depth don't sound like much room. all the after market speakers are 2-2.5 depth. would the aftermarket ones fit?
In mine I built spacers and put 6 1/2 up front and 5 1/4 in the rear
See attached pics.
Attached Thumbnails Door Speaker-front-c240-w-spacer.jpg   Door Speaker-rear-speaker.jpg
Old 05-15-2012, 06:42 AM
  #32
Eemo1's Avatar
ok, ordered jbl gto's for all doors with some dynamat type stuff...
getting nervous about replacing them already, haha! i hope I don't screw anything up...
Old 05-16-2012, 12:05 AM
  #33
Harleyl7's Avatar
I got four pioneer speaks put in over the weekend and its 6.5 all around. at first they sold me 6.5 front and 5.2 in the back but they realized the 5.2 didn't fit. its 6.5 all around.
Old 05-16-2012, 01:50 AM
  #34
Eemo1's Avatar
got pics?
Old 05-16-2012, 08:32 AM
  #35
xijonix's Avatar
2004 Mercedes-Benz C Class
Yeah 5.25 only works with an adapter, mounting flush to the door you'll have to use 6.5 as they barely clear for drilling into the metal. Just got my 8" sub installed in the rear deck and damn does it sound good. Just the right amount of bass. Using an Alpine Type R 8" Woofer handle 350W, pushing with MRP-M500. Will take a pic and post it soon, I highly recommend this for people who are looking for low end.
Old 05-16-2012, 10:46 PM
  #36
Harleyl7's Avatar
got pics?
No pics sorry, but they sound great and with my 10" sub in the trunk.
Old 05-16-2012, 11:44 PM
  #37
xijonix's Avatar
8" Subwoofer Rear Deck Install
8" Mounted Alpine Type R 350W RMS Handle w/ MRP-M500 500W RMS amp, all on the rear deck. I did door speakers but it didn't give me the low end I needed. In fact it reduced the low end but provided great mid-high end and cleaner low end instead of distorted low end audio. But it wasn't cutting it so did this a few days ago.
Old 05-17-2012, 01:58 AM
  #38
Peydidy's Avatar
C63 AMG
I like that LED strip you have in there, what did you wire it too?
Quick Reply: Door Speaker
