What's a good brake caliper paint?
Old May 18, 2012 | 10:09 PM
silvermamba's Avatar
2005 C230
Old May 19, 2012 | 01:40 AM
phister's Avatar
06 C230 SS 6spd
Duplicolor, vht,.and of the ones at the auto store. Just prep it right and you'll be ok. You can use engine paint as well since it can withstand high temp. I used duplicolor metalcast on mine to get the anodized look.
Old May 21, 2012 | 10:16 AM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Or you could just buy the G2 kit; Tirerack and probably thousands of other retailers sell them - self-contained, and easy to DIY.
Old May 21, 2012 | 12:03 PM
J.Christian's Avatar
(W203s) '04 C240, family member '05 C230 Kompressor
Or, if you want an easy job with no prep and only want basic flat black... Use charcoal grill paint. Resists heat... doesn't peel... same color as brake dust... It is also good for the edges of the rotors if they are rusty. You don't have to mask any overspray on the rotors will grind off the first time you use your brakes leaving only black finish on calipers and edges of rotors. I did this on my standard C240 brakes but probably wouldn't do it on the nicer calipers on a sport package. They look good as they are or I would prep and do a different color on them probably.
regards,
Jamie
Old May 21, 2012 | 10:27 PM
WaveyKat's Avatar
Something Slow
G2 all the way
Old May 22, 2012 | 01:38 AM
Peydidy's Avatar
C63 AMG
I used the auto zone ones, they have this kit for $20 that comes with the paint, brush, tape, and caliper cleaner
