itermittant lock and unlock problem
I'm going to look at it tomorrow. the last time the fuse blew, the front fogs were flashing, so I'm going to start with the siren. I'll let you know what I find.
Pulled passenger front wheel well liner, disconnected siren, and fuse F8 no longer blows. New siren from dealer installed. Put everything back together, and both remotes work properly again. Radio signal back to normal also.
If the remotes stop working "suddenly" (nothing to do with recent tint job), and F8 is blowing, I would definitely check the alarm siren BEFORE pulling the headliner or C Piller cover to check the antenna amplifier
If IR works, then that leaves RF. Common problems on RF could be metalic tint (which will block the RF signal), or a bad RF antenna amplifier (which could have been damaged when tint was installed/trimmed).
Check the IR and get back to me.
