Star DAS menu paths for mods (pre-facelift W203)
Old Apr 7, 2015 | 11:35 PM
  #51
jrsmith_68's Avatar
Veteran: Army
2007 C350 2015 ML400 1968 Ford Mustang
Menu in Front SAM
Attached Thumbnails Star DAS menu paths for mods (pre-facelift W203)-front-sam.jpg
Old Apr 20, 2015 | 10:39 PM
  #52
RWDlifer's Avatar
2005 C230K SS
How do I view live engine data in DAS? I've spent lots of time fiddling with different control units but never figured out live data..
Old May 29, 2015 | 06:59 PM
  #53
jpman's Avatar
2009 E63
Originally Posted by VVF
Ok, so if someone is still struggling with tire pressure warner.
I have a 2005, and I didn't see Tire pressure warner in the ESP menu.
This is what I did:
Body -> EZS -> Control unit adaptations ->
Read coding and change if necessary ->
All codes ->
Scroll down to 2nd screen and enable 'Tire pressure loss warner'
Then carry out the coding
I then removed and inserted the key.
After this the TPLW menu item appeared under ESP
Now, I haven't driven 60 miles yet, but I intend to test it somehow after that...
VVF thanks for the info. I finally got a chance to do this one. I got through the part of removing the key and putting it back in. It mentions resetting cluster actuations or just simply recoding something on the car. I chose to recode by enabling the turning lamps or active fog lamps.
I have not driven the car for 60 miles yet, but when you go to the odometer menu and scroll through it it says to press r to reset tire pressure warning. Does this mean that I successfully enabled it?
how do you specifically enable this part of it "8/ enable warning in cluster menu behind odometer".
what should it say in terms of enabling a warning. I get something that says resetting tire pressure by pressing the reset button on the cluster.
Old Jun 1, 2015 | 04:26 PM
  #54
TelmoChaparro's Avatar
C 220
when you see Tyre Presure OK, change to yes and wait...it will give you a message...
Old Jun 2, 2015 | 11:26 AM
  #55
jpman's Avatar
2009 E63
I am not sure I get those same messages. This is a video of what I get.
As you can see in this video, I get not such thing as "tire pressure ok".
If someone can post a video or pictures of what we should be getting it would be great.
Old Jun 4, 2015 | 01:28 PM
  #56
jpman's Avatar
2009 E63
Never mind. I finally tested it by lowering the pressure on one of the tires by 5 PSI and the warning message came out.
Old Nov 23, 2018 | 12:32 AM
  #57
krazzdav's Avatar
Veteran: Marine Corps
2017 GLA 250, 2011 C63 P31 (p30 w/ lsd) (in repair), 2005 C230 Sport Eurocharged, 2003 C320~sold
For those that don't know what the Netherlands alarm sounds like here is a vid
W203 Netherlands Alarm Sound
Old Dec 28, 2018 | 06:22 PM
  #58
oguzhan.kayhan's Avatar
w203
Another star question is coming from me..
I want to install aux pump to my 2002 w203
It has electric plug but no 12v on it.
I think rest function or maybe something special about auxpump should be enabled via star
Is there anybody that can show me the path for it?
My mechanic has no clue in using star.. Just simple diagnostics..
But if I can get any info from here , he is willing to help me on this
Regards
Old Mar 9, 2019 | 10:09 PM
  #59
wanderlust360's Avatar
2003 C230 Sedan Manual
Does the tire pressure warning require your car to be equipped with TPMS pressure sensors, or does the ESP just sense that a wheel is not rotating as usual? I was able to enable this option in the EZS menu only. But it did not show up in the ESP menu before or after, so I am stuck. I have a 2003 C230 Kompressor sedan model.
Old Feb 9, 2022 | 10:28 AM
  #60
Zaki0606's Avatar
W203
active fog light
I have a Mercedes-Benz w203 modele 2005 i want to actived cornings light with Star diag. Help me please !
