Caster links and bushings? Also coil spring advice.
mercedes c320 wagon 2002
1. I took my 2002 C320 in for an alignment and I was told that the "caster link and bushings" needed replaced. I replaced the front control arms and bushings last year. I've been searching online, but I can't find "caster links" on the forums.
Are caster links known by another name?
2. I was also told my right real coil spring was broken. If I am going to replace this coil spring would you suggest replacing both rear coil springs or just the broken one?
I appreciate the advice. Thanks.
