Caster links and bushings? Also coil spring advice.
Are caster links known by another name?
- 2.
I appreciate the advice. Thanks.
- 2.
2.) I would change both, as the other has probably "settled" a bit over time.
Good Luck on it. Greg
Fit fluted bolt kit while you are changing them then you can adjust castor.
