Which way do you guys change your motor oil?
I use an extractor. But I did drain out the oil once the hard way by removing all the panel because I did not know what the previous owner put in there.
However, when I purchased the car, my first two oil changes were "lift and drain" just because I had no idea what oil was in there from before.
i can change the oil without jacking.
this includes removing plastic shroud, and drain plug.
(long arms).
i do however, use the jack on the drivers side front, just a couple pumps on the jack, to make sure to get all the oil out. (my drain plug faces passenger side.)
and i let it drain for about an hour.
this does, get most of the oil out.
Last edited by misterwhite; Jun 23, 2012 at 01:54 AM. Reason: i digress, impossible to gel ALL the oil out.
With so many swearing (sometimes literally) by one method or the other, there is probably not much difference. If there were a measurable difference, you'd know it and it wouldn't be rumor anymore. Occam's razor gives a very nice shave.
You are not draining everything out even by tilting the car, anyhow. There is about half a liter of oil that will not drain back to the sump. The new oil and the old will mix just fine. There will be a slight dilution of the additive package in the oil as a whole, but the engineers know this. This is the reason they do not suggest any additives (except Techron under limited circumstances) that might further dilute the oil.
I drive until I reach operating temperature, open the hood, shove the tube down the dipstick hole and pump. Remove oil filter, replace four O rings, install filter. Fill with new oil, and enjoy an adult beverage.
As directed I use it one a month in my two Mbs and have used it in all my cars since 95. It does work, unlike the junk you see advertised on Saturday am car tv programs. Around here we can get Shell 93 unleaded and I still use it.
And if there are leaks with the seal washer something is wrong. I must have over 600k miles with Mobil 1 and haven't had a leak from the drain plug yet.
There is no need to crawl about on the ground removing panels and the plug to drain the oil. Use an extractor like the dealers are using to suck the oil out. Warm the car to operating temperature, stick the plastic tube down the dipstick tube, and pump the hand pump a few times and the oil will be vacuumed into a holding tank. Check mity-vac on Amazon:
You can then carry the Mity-Vac to the auto parts store to dump the oil. Clean and neat.
http://www.meijer.com/s/seasense-12v...&cmpid=goobase
