p0010 on m271
Old Jun 26, 2012 | 01:23 PM
1beege's Avatar
p0010 on m271
Would it be possible for a cam to be off one tooth and set the p0010 code? After doing a valve job I am getting this code. Car runs great but sometimes idles rough when under load. I have read this forum for hours before asking, thanks for any help. M271
Old Jun 26, 2012 | 02:22 PM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
P0010 - Component Y49/5 (Right camshaft intake solenoid) has an open circuit in the wiring.
P0010 - Continuous camshaft adjustment ( RIGHT ): Incorrect position of the intake camshaft
P0010 - "A" Camshaft Position Actuator Circuit (Bank 1)
Old Jun 26, 2012 | 02:39 PM
1beege's Avatar
I know the code, but just wonderiring if it could throw that code from not being able to properly psition the cam if it is a tooth off? I swapped magnets and same code.
Old Jun 26, 2012 | 02:45 PM
So then why don`t you re-position the cam one tooth in the right direction and test your hypothesis,...
BTW, open circuit,.... did you make sure your plugged all the connectors back in properly,.... did you clean them too,...
