Chevron vs Lucas vs STP
I have a very, very subtle valve tap at start up that seems to go away as the car heats up.
About your "valve tap"... How many miles do you have on your car? Are you sure it is valve tap? It sounds like it could be the timing chain is a little loose. That is not something you want to mess around with. It needs to be dealt with quickly.
I run Techron on a regular basis.
Also, the mention of the timing chain is a good catch! Does your noise only happen for a second during cold start? If so you need to stop running the car now until you can get the timing chain replaced.
