Specific steps plz for unclogging leaves from ac intake
Old Aug 20, 2012 | 03:18 PM
Ivanrad's Avatar
2001 C320 Automatic
I have a bunch of leaves clogging my ac intake near the windsheild wipers , how do i remove this and clean it ? Ive got a hi power vaccum to clean it out . Thank you
2001 c320 w203
Old Aug 21, 2012 | 12:40 AM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
yeah, suck ,... don't blow
Old Aug 21, 2012 | 02:17 AM
bimo2700mf's Avatar
C180 Kompressor 2003
there a link in the wiki page w203 hvac you can check the diagram & component of ac system in there
i hope that can help you
Old Aug 21, 2012 | 03:33 PM
Ivanrad's Avatar
2001 C320 Automatic
No no no . Show me on that guide that you just showed me , where the intake through the windshield wipers is located . The air is sucked in Through the outside windshield . How do i remove this plastic shield where the tunnels are clogged .
Old Aug 21, 2012 | 04:44 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
The air is sucked in by the battery, no? There's a cabin filter there.
Old Aug 22, 2012 | 01:04 AM
bimo2700mf's Avatar
AFAIK the air flow from the outside to the cabin through air filter below the battery, if the problem with the intake through the windshield then you can just vacuum it using high power vacum cleaner or try to blow it using air compressor the out take of the air should be around the cabin filter, please check it first before blow it using air compressor
