which lug bolts for 15mm spacers?
Old Aug 30, 2012 | 06:01 PM
StillNDADIRT's Avatar
2002 C230 Coupe
Im putting 15mm spacers up front on my 02 c230 coupe and need the longer bolts. Im still running the stock 16" allows. What size bolts should i get and where? Thanks
Old Aug 30, 2012 | 06:56 PM
phister's Avatar
06 C230 SS 6spd
55mm shank. Our stock shank is 39.9mm or 40mm. Go to radusadirect.com believe our ball seat is R12
Old Aug 30, 2012 | 07:00 PM
phister's Avatar
06 C230 SS 6spd
Here's what you want
http://www.radusadirect.com/product/...at-Hex-17.html
Old Aug 30, 2012 | 07:10 PM
2002 C230 Coupe
Alright thanks. My front tires are stock size and seem like they will rub the coilover even with the 15mm spacer from it being so low. I guess im going do get smaller front tires. Whats the smallest tire i should put on the front 16s
tommy's Avatar
2004 Civic Si. FWD for the Win!
You should think about converting to studs - makes the whole process much easier.
Old Aug 30, 2012 | 07:46 PM
phister's Avatar
06 C230 SS 6spd
You probably just want a thinner sidewall. What tire size you have. With tires the first number is the width second is sidewall height which is the percentage based on the width third is tire dimension
Old Aug 30, 2012 | 07:47 PM
phister's Avatar
06 C230 SS 6spd
So sidewall with a 40 is 40% of the tire width
Old Aug 30, 2012 | 08:07 PM
2002 C230 Coupe
I think they have 205 55 16 on them now front and back
Old Aug 31, 2012 | 09:56 AM
2002 C230 Coupe
So should i look for something like 205 40 16 ?
Old Aug 31, 2012 | 11:32 AM
phister's Avatar
06 C230 SS 6spd
Yea I would go for a 205/40/16
Old Aug 31, 2012 | 01:42 PM
2002 C230 Coupe
Alright so what size should i put on the back since the rear wheels are wider?
Old Sep 1, 2012 | 09:37 AM
phister's Avatar
06 C230 SS 6spd
are the wheels staggered? if not I'd do the same size all around that way you can get more out of the tires and you can rotate them to all four corners.
Old Sep 5, 2012 | 10:38 PM
2002 C230 Coupe
I would put the same on the back but these wheels are staggered
Old Sep 6, 2012 | 06:55 AM
phister's Avatar
06 C230 SS 6spd
Do 215/40/16
Old Sep 6, 2012 | 07:00 AM
Bnzova's Avatar
W203 06
Get some stretched tyres. Should minimize rub.
