HELP!!! Dangerous Throttle Lag
Old Sep 4, 2012 | 07:25 PM
TTR's Avatar
TTR
R129 SL500 & W140 S500
I have to put the pedal through the floor and count out five seconds before the car will start to budge. Engine shuttered a bit at idle and shook the whole car. I have absolutely no idea what's wrong and it's not the carpet since the design prevents that from being an issue. Any one have any idea what is wrong with it?
Thx.
Old Sep 4, 2012 | 07:59 PM
mtnman82's Avatar
'16 E350, gone: '03 c230k
Have you tried resetting the throttle to see if there's any change(instructions in one o fthe sticky's at the top of the forum)?
Old Sep 4, 2012 | 08:54 PM
phister's Avatar
06 C230 SS 6spd
you have any CEL? might be your plugs or crank sensor.
Old Sep 4, 2012 | 10:27 PM
TTR's Avatar
TTR
Not sure what CEL is. But it somehow went away just an hour ago. It happened a couple times while driving before but never consistently during an entire drive. Should I still do the throttle reset?
Old Sep 5, 2012 | 04:02 AM
phister's Avatar
06 C230 SS 6spd
its always good to do a throttle reset every now and then
CEL= Check Engine Light
Old Sep 7, 2012 | 06:29 PM
TTR's Avatar
TTR
Oh no CEL at all. Gonna do the reset and have the computer scanned when I swap tires for winters.
Thx again for everyone's advice.
Old Sep 9, 2012 | 06:04 PM
Robert Clutter's Avatar
Similar Problem
I have a similar problem with my 2002 c230 kompressor. I have replaced the MAF and both o2 senors changed the furl filter and ran a compression test all with no change. I have CEL on and have (I cant remember the code) but the fault seems to be in bank 1....The car will idle a little rough and then smooth out but once in reverse or drive the car has a real hard time moving at all even when I remove my foot from the accelerator and apply load the car sputters and feels as if it will die(no back fire) I am tempted to clean the injectors but can not find the service port that will allow me to access the injectors on the car....I need real help here I am close to rolling the car down and hill an walk away HELP
Old Sep 9, 2012 | 06:11 PM
biker349's Avatar
cl600
ignition coil, throttle accuator, bad accelerator pedal?
Old Sep 9, 2012 | 06:18 PM
I have checked or replaced all of those items I am out of ideas and hope at this point how do I reset the trottle?
Old Sep 9, 2012 | 11:26 PM
otmal's Avatar
2001 C320 100k miles
2 or 3 yrs ago, it happened to me, no cel, delayed throttle, engine shock
whole car.
I replaced the throttle pedal module.
problem solved.
no car reprogramming by dealer needed,
Old Sep 10, 2012 | 03:57 PM
raceral's Avatar
2002 C320
My 02 c320 is doing the same thing right now.. in a few min. I am going to try the throttle reset thing.
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor and hold for five seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
