Slight bottom end hesitation. 02' C320
2002 C320
I have been having a slight hesitation just when I slightly start accelerating, like the first 1/8 throttle. Idle about 500/600 rpm.
It does it like 3 out of 10 times.
I have changed plugs (wore out)Bosch
I have changed wired Bosch
Air filter
Fuel Filter (Mahle)
Checked codes, nothing.
Wife drives drive the car and says it scares the crap out of her.. we all know that is not good.
Car runs like perfect otherwise, no skips,or anything... just when you first take off.
What should I check next...
Air filter
Fuel Filter (Mahle)
I keep woorying about the car dying at a stop sign , because other drivers want to move fast, luck if they allow you the time to have your turn , so far it never died on may, but it makes you feel the pain when you first start to move, i will take it to the shop , see if any thing possitive . Thanks for the reply .
No lights are up , no malfunctioning, every thing is working perfect with the exception of hesitation and acting like it wants to die at stop signs and traffic signals . and if I push the gas Paddel a lttle more , it will fly and might hit someone in the front, hahahah .
