Lets talk intercoolers (FMIC)
Old Oct 11, 2012 | 11:19 AM
torake's Avatar
C180 Kompressor Wagon
Originally Posted by jetta02awp
As for boost pressure. Hook up a boost gauge to find out. I have an m111 so I don't know about the m271. I'm pretty sure you could tap off somewhere near the throttle body to find out post intercooler boost and tapping off the fuel pressure regulator will give you actual boost that the supercharger is producing.
Boost pressure (actually MAP), along with other useful readings such as IAT is available in the OBD2 connector. No need to attach boost gauge.
Old Oct 11, 2012 | 03:32 PM
Mugello's Avatar
W203 C180k
I wouldn't mess with the size of the piping. I'm sure mb thought this out when they designed it. As for boost pressure. Hook up a boost gauge to find out. I have an m111 so I don't know about the m271. I'm pretty sure you could tap off somewhere near the throttle body to find out post intercooler boost and tapping off the fuel pressure regulator will give you actual boost that the supercharger is producing.
I understand what your saying This is why im only investigating at the moment.
Also thanks for the information about the different boost readings i could get
Originally Posted by MBfinatic
Before and after test would be great. I think the M271 C230k runs 11 psi? I may be wrong.
Yes i would get a before and after reading for boost should i go ahead with this modification.
Also 11 psi rings a bell.
Interesting, would also be more accurate than a gauge !
