Coolant leak 2000/2001 C220 cdi
Hi people.
I have recently bought my first MB a 2000/2001 c220cdi and after just a week i have found out i have a coolant leak![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
I have been looking over the different hoses and i think/hope i have pinpointed the problem.
On the expansion tank for the cooling system there are mounted 2 electronic thingies ( yeah...i dont know what their called since they are not even in haynes rep books ^^) Although one of them wich has a thin hose going down and under the left hand side of the motor has a part number A 000 545 05 271..the thin hose that goes from the part with this number seems to be leaking somewhere on the way down to where it is fitted on the bottom of the motor.
I have tried searching google for the part number but that spesific number simply does not show up anywhere.
I was hoping someone here would be able to help me find out what part this is and what number the hose i need has.
On top of the electronic (pump?) with the part number A 000 545 05 271 it also says VAC where a thin hose goes and OUT where the hose in question comes fitted.
In advance thnx
Lasse.
In advance thnx
Lasse.
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
If you have an OM 646 engine:
![](https://mbworld.org/forums/attachments/c-class-w203/246243d1351357776-coolant-leak-2000-2001-c220-cdi-om646-surge-tank.jpg)
11 A 003 997 17 89 .SEALING RING
LEFT BOTTOM
36,3MM 001
30 A 006 997 05 90 CLIP
COOLING WATER HOSE TO WATER PUMP
36-46 MM 001
55 A 203 501 58 82 COOLANT HOSE 001
65 A 026 997 78 48 .SEALING RING
TOP LEFT 001
65 A 003 997 17 89 .SEALING RING
LEFT TOP
36,3MM 001
70 N 000000 0002775 CLIP
HOSE TO ENGINE 001
105 A 203 501 01 25 BREATHER PIPE 001
180 A 203 500 00 49 DASHPOT
COOLING WATER EXPANSION 001
190 A 220 545 00 24 .SWITCH,AUTOMATIC
COOLING WATER LEVEL INDICATOR 001
200 A 210 501 07 15 CATCH
COOLING WATER EXPANSION TANK
Replaced_By: A 000 501 82 15
OptionPart_With: A 000 501 82 15 001
200 A 000 501 82 15 RADIATOR CAP
OptionPart_With: A 210 501 07 15 001
210 A 003 990 53 51 NUT
EXPANSION TANK TO RIGHT FRONT WHEELHOUSE
M6 001
220 A 203 504 02 12 RUBBER BEARING
EXPANSION TANK TO RIGHT FRONT WHEELHOUSE 001
230 A 000 584 08 07 .PLATE
EXPANSION TANK 001
230 A 210 584 07 21 GUIDE SIGN
IN ENGLISH Code: 221B
001
230 A 210 584 08 21 GUIDE SIGN
IN FRENCH Code: 222B
001
230 A 210 584 09 21 GUIDE SIGN
IN SPANISH Code: 223B
001
230 A 210 584 99 17 GUIDE SIGN
IN PORTUGUESE Code: 224B/209B
001
230 A 210 584 28 21 GUIDE SIGN
IN ARABIAN Code: 623
001
435 A 203 501 38 82 HOSE 001
635 A 220 545 00 24 .SWITCH,AUTOMATIC
645 N 000000 0001114 SCREW
CLAMP TO CYLINDER BLOCK
M6X15 001
LEFT BOTTOM
36,3MM 001
36-46 MM 001
TOP LEFT 001
LEFT TOP
36,3MM 001
HOSE TO ENGINE 001
M6 001
EXPANSION TANK 001
001
001
001
001
001
M6X15 001
Super Moderator
In addition to the above there should be an axilliary heating pump that feeds the heater/aircon (HVAC) unit in the car when the engine is not running.
Your "A 000 545 05 271" is NOT a valid part number. Mercedes-Benz part numbers usually have the following format A###-###-##-## (sometimes followed by more numbers to denote more specific colour or trim for that particular part).
Better to post a photo of the part instead of trying to describe it as there are thousands of parts all over the engine bay.
A good place to research part number is www.mbpartsworld.com (no affiliation to mbworld.org) where you get the basically the same info that the parts department of the Mercedes-Benz dealership would have.
The electronic thingy coming from the bottom of the coolant expansion tank is the coolant level sensor.
Yes i think this one is for the auxillary heating pump since i do have a heater system to keep the car warm up to 30 minutes after the motor has been shut down.
From the sketch(not good in english) or drawing u post i am missing the part i am talking about. the other one on ur sketch is there but my part with the hose that has an apparant leak is missing from it so i guess that is the auxillary heating pump mechanism.
And to Sunny..i know the part number does not exist since ive been using google and every other search mechanism i could think of ( im from norway and even here nobody can find the part.
The funny thing is the part number is stamped on the heating pump in clear letters so it IS a correct part number![Big Grin](https://mbworld.org/forums/images/smilies/biggrin.gif)
The thing for me now is to find out where to get the hose from that pump down to the engine and if this hose is just something i can pull loose and exchange....i never thought an auxillary heating system could keep draining my coolant fluid alone but it seems that is the case.
![](http://img62.imageshack.us/img62/7831/wp000280d.jpg)
![](http://imageshack.us/a/img87/2193/wp000281.jpg)
![](http://imageshack.us/a/img845/8717/wp000278.jpg)
![](http://imageshack.us/a/img194/166/wp000277k.jpg)
![](http://imageshack.us/a/img547/8245/wp000278u.jpg)
![](http://imageshack.us/a/img843/2858/wp000281zn.jpg)
on image 2 it is the hose with the small yellow band around it that probably has a leak down by the engine. on picture 1 u see the same hose and it seems the final 4CM or so has a leak bfore the 90 degree angle up and attatching to the engine block.
I`ve never seen that part before. That is obviously a rare part. You will likely need to do to your local dealer for that part,... the electronic pump. But it seems that you only have a leak in the hose that attaches to it. There doesn`t seem to be anything special about that hose, in terms of its shape. If you can`t get the hose from the MB dealership, I would suggest using a generic hose from an automotive parts store. You need to measure the ID (inner diameter) and OD (outer diameter),... ID is most important and figure out the length,.... and any hose clamps needed. Should be rather simple to change yourself,... you might have to use a clamp to clamp off any coolant upstream from this hose so you`ll minimize coolant lost,.... or just do it as part of a coolant change.
FYI,... that fist size metal cylinder beside it with the wires sticking out from the top is the auxilary coolant pump to pump coolant to the interior of the car.
Super Moderator
Here is the heater circuit:
![](https://mbworld.org/forums/attachments/c-class-w203/246252d1351376622-coolant-leak-2000-2001-c220-cdi-om646-heater-connection.jpg)
10 A 203 830 47 96 SHAPED HOSE
FROM ENGINE TO CONNECTING TUBE 001
20 A 000 995 40 05 HOSE CLAMP
HOSE TO ENGINE
27 MM Code: 612
001
27 MM 001
30 A 203 830 41 96 HOSE 001 L
30 A 203 830 42 96 HOSE
FROM CONNECTING TUBE TO HEAT EXCHANGER 001 R
30 A 203 830 39 96 HOSE
FROM CONNECTING TUBE TO HEAT EXCHANGER Code: 875
001 L
30 A 203 830 40 96 HOSE
001 R
32 A 203 506 18 35 .HOSE
FROM CHECK VALVE TO PIPE LINE Code: 228
001
36 A 203 506 19 35 .HOSE
CHECK VALVE TO COMBINATION VALVE Code: 228
001
40 A 203 506 17 35 .HOSE
COMBINATION VALVE TO COUPLER Code: 228
001
42 A 203 506 20 35 .HOSE
COMBINATION VALVE (FEED TO VEHICLE HEATING) Code: 228
001
34 A 000 203 56 64 .VALVE
CHECK VALVE Code: 228
001
44 A 007 997 20 90 .CLIP
HOSE TO VALVE
22/12 MM Code: 228
002
46 A 230 995 01 05 .CLIP
HOSE TO VALVE
24.0/26.8 MM Code: 228
003
38 A 000 203 62 64 .VALVE Code: 228
001
50 A 230 995 01 05 CLIP
HOSE TO HEAT EXCHANGER
24.0/26.8 MM 001
60 A 203 830 01 15 PIPE LINE
FROM HEAT EXCHANGER TO WATER VALVE 001 L
48 A 000 995 40 05 .HOSE CLAMP
HOSE TO CLUTCH
27 MM Code: 228
001
60 A 203 830 02 15 PIPE LINE
FROM HEAT EXCHANGER TO WATER VALVE 001 R
65 A 230 995 01 05 CLIP
24.0/26.8 MM 001
67 A 000 994 31 48 FUSE
HEATING LINE MOUNTING 001 R
70 A 203 830 07 96 HOSE
RESERVOIR Code: 670/581/874/875
001
75 A 230 995 01 05 CLIP
HOSE TO GROMMET
24.0/26.8 MM 001
HOSE TO RECIRCULATING PUMP
24.0/26.8 MM Code: 450/580/581/670/874/875
001
24.0/26.8 MM Code: 450/-228+670/581/874/875
001
24.0/26.8 MM Code: 450/670/581/874/875
001
24.0/26.8 MM Code: 670/581/874/875
001
80 A 006 997 42 90 CLIP
HOSE TO RESERVOIR
28/35 MM 001
80 N 000000 0002772 CLIP
HOSE TO T-FITTING
40 MM Code: -581-670-874-875
001
90 A 203 830 19 96 .HOSE
RESERVOIR 001
100 A 203 835 00 64 RECIRCULATING PUMP [114], [115], [116]
Code: 450/670/581/874/970/974/975/580
001
100 A 203 835 01 64 RECIRCULATING PUMP
HEATED SCREEN WASH SYSTEM Code: 875/670+875/581+875/874+875
001
110 A 203 830 49 96 HOSE
FROM WATER VALVE TO ENGINE [117], [118]
001
110 A 203 830 53 96 HOSE
FROM WATER VALVE TO ENGINE [119], [120], [121]
001
110 A 203 830 50 96 HOSE
Code: 670
001
Code: 581
001
Code: 874
001
Code: 875
001
110 A 203 830 54 96 HOSE
Code: 670
001
Code: 581
001
Code: 874
001
Code: 875
001
120 A 230 995 01 05 CLIP
001
001
001
001
120 A 006 997 42 90 CLIP
HOSE TO ENGINE
28/35 MM
Replaced_By: A 006 997 03 90 001
120 A 006 997 03 90 CLIP
HOSE TO ENGINE
23/30 MM 001
130 A 203 988 01 27 GROMMET
HOSE THRU ENGINE COMPARTMENT PARTITION PANEL
Replaced_By: A 000 998 39 02 [051], [126], [127], [128]
001
130 A 000 998 39 02 CABLE GROMMET
HOSE THRU ENGINE COMPARTMENT PARTITION PANEL [129], [130], [131]
001
130 A 000 998 48 02 CABLE GROMMET
HOSE THRU ENGINE COMPARTMENT PARTITION PANEL [132], [133], [134]
001
140 A 203 988 02 27 GROMMET
HOSE THRU ENGINE COMPARTMENT PARTITION PANEL 001
150 A 203 830 10 15 PIPE LINE
BYPASS LINE TO WATER VALVE Code: 875
001 L
150 A 203 830 11 15 PIPE LINE
001 R
160 N 000000 0000665 CLIP
HOSE TO HOSE
13/22 Code: 875
001
HOSE TO RESERVOIR
13/22 Code: 875
002
HOSE TO PUMP
13/22 Code: 875
001
170 A 203 830 09 96 HOSE
FROM RESERVOIR TO PUMP Code: 875
001
200 A 000 995 61 14 CABLE HOLDER INSTRUMENT C
HOSE AND WIRING HARNESS 001
HOSE TO ENGINE
27 MM Code: 612
001
27 MM 001
001 L
001 R
001
001
001
001
001
HOSE TO VALVE
22/12 MM Code: 228
002
HOSE TO VALVE
003
001
24.0/26.8 MM 001
HOSE TO CLUTCH
27 MM Code: 228
001
24.0/26.8 MM 001
001
HOSE TO GROMMET
24.0/26.8 MM 001
001
001
001
001
HOSE TO RESERVOIR
28/35 MM 001
HOSE TO T-FITTING
001
RESERVOIR 001
001
001
001
001
Code: 670
001
Code: 581
001
Code: 874
001
Code: 875
001
Code: 670
001
Code: 581
001
Code: 874
001
Code: 875
001
001
001
001
001
HOSE TO ENGINE
28/35 MM
HOSE TO ENGINE
23/30 MM 001
001
001
001
001 L
001 R
HOSE TO HOSE
13/22 Code: 875
001
HOSE TO RESERVOIR
13/22 Code: 875
002
HOSE TO PUMP
13/22 Code: 875
001
001
Super Moderator
It is also possible that your car is fitted with an engine heated screen washer system or A fuel heater for very cold climates.
Yeah it is not the engine heated screen washer system since that one here in norway is fueled by the screen washer liquid and not the coolant..but a fuel heater. On my car wich is the diesel it does not have a pre heating diesel system for some odd reason but it DOES have a diesel heating system for when the engine is off to reserve some of the heated fluids to keep the car warm by using the power from the battery for up to 30min or how long the battery might last without emptying it to keep the car warm.
Now the weird part even here in europe and on every mercedes part list i have been able to find the pump/electrical item the hose is connected to does not exist on any part site i have been able to find. Even the mercedes benz national club im a member of have been able to find the correct part anywhere wich is just seriously weird ;D
Even the latest heating circuit u posted glyn does not correspond with the one attached to my cooling expansion tank...No matter i will meassure the hose and find a corresponding one but the part that not in the US or here in Europe nobody can seem to find this part even in MB's own part list is pretty weird!
It's quite possible that particular hose does not have an official MB part# if it is only sold as part of a package with the electrical pump up above it. There are a number of small MB parts like that,.... for example the o-rings for the transmission pilot bushing adapter (electrical plug), it used to have its own separate MB part number and could be brought separately. But now you can only get that o-ring when you buy the transmission pilot bushing adapter which includes the o-ring as a package.
Anyways, if you are really fussy about getting the exact hose,.. inquire at your local Mercedes Benz dealership part department,.... the worst that can happen is that you get hosed!
I have the 611 engine. My problem is now solved!
I took it to the MB dealer garage...they spent half a day scratching their heads trying to find out about this but finally they did!
The hose is changed and the car is back in action..
Unfortunatly the snow and cold has arrived so ill have to just dream all winter off what else i can do with the car next spring.
Thnx alot for trying to help me out.
