Reverse Issue
Old Oct 30, 2012 | 05:58 AM
mpjsols's Avatar
W203 C270CDI
Reverse Issue
I would be grateful for any suggestions on this one please !
Once of those weeks! Car threw an EML, then when parking, could not select reverse or neutral. Could drive home. Next time , EML On, stuck in second gear, C/S light off on the gear display. If engine off and key out , then restart and could change gear selector.gear change reverse to drive is more clunky if that makes sense.
I think either TCU or speed sensor causing lockout, generic TCU error on OBD-ii ,P0702 - Open or short transmission control module circuit - Poor transmission control module electrical connection - Faulty transmission control module - Transmission control module not coded
On a UK (RHD) car is the TCU on the drivers side, and if so how do you get the carpet from under the throttle without too much dissasembly.
Any similar experiences, it is a low mileages 190K 2004 C270 CDI,
Thank
Old Oct 30, 2012 | 10:51 AM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
check trans fluid..and the AT plug adapter for leaks
since u have a code for tcu...your plug adapter could be leaking causing fluid to wick up the harness and into the computer (my mechanic claims this almost happend but charged me 600 in labor to clean the harness and replace the park lock seals)
just pull back the floor panel closest to the engine
Old Oct 31, 2012 | 02:36 AM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Sammny's learnin'. Like he said, oil in the TCU, pull up the carpet and be knowin'.
OR could be glycol on the fluid.
Had it ever had a full flush?
Old Oct 31, 2012 | 12:30 PM
Glyn M Ruck's Avatar
Super Moderator
Sounds like the typical electrohydraulic pilot bush leak problem. $10 part.
Old Nov 9, 2012 | 07:40 AM
mpjsols's Avatar
W203 C270CDI
I have been travelling but will get in and look at the TCU under the carpet this weekend. It has had a full flush about a year ago, when I think they replaced that seal...
Old Sep 15, 2014 | 01:37 PM
mpjsols's Avatar
W203 C270CDI
Result
Forgot to update on this one, basically a new shifter unit. UKP 70.00 from a breaker resolved the issue, it was the position indicator switch in the actual gear shift unit in the car.
