2005 c240 Gear Problem
Was your grade in school was D+ or D-
hessa ~ see diagram. To manually shift up and down if revs are safe to do so you tap the lever left or right. There is no display for this on some clusters. If your transmission is not reacting to left or right movement of the selector then it's likely that the selector switches have become gummed up. Remove the selector & clean the switching mechanism with a good switch cleaner.
Do I need to open the shifter? I found some disassembly instructions for bmw but I don't know how to do it in w203?
http://www.ebay.com/itm/2001-2002-20...0b1858&vxp=mtr
https://mbworld.org/wiki/index.php/F...er_console.pdf
Inoperative touch shifting will not throw a code. It is not part of the OBDII regime. If it was a shift plate or conductor plate issue it would throw a code.
The only time the touch shift should refuse a downshift is if the engine would exceed max RPM.
Good luck!
