What is top speed for c230k
Acura Integra GS
I recall seeing 130mph someplace, but can't find it anymore on google. Can anyone verify the top speed of the c230k?
I also recall reading that the top speed was electronically governed. So the next obvious question is how to get around that?
Thanks,
DT
Thanks,
DT
1 Post
2005 smart cabrio; 2008 Mercedes-Benz B 200
Höchstgeschwindikeit
The EU brochure lists the top speed of the C 230 K as 240 km/h (149 MPH). That's for the manual; the auto is a bit slower.
The US/CDN ones have crappy standard tires, H-rated (210 km/h), so the speed limiter should kick in around 127-129 real MPH (likely a tick or two over 130 on the speedo).
2006 MB C230 SS 6spd, Navi
Max Speed
I have actually had the speedometer up to 135 before the limiter kicked in. Shortly thereafter my radar detector started going off. At this point I executed emergency maneuver SRF (Stop Real Fast). The cop pulled me over said I was doing 90. About 20 Seconds elapsed from the time the radar detector started going off till I saw the cop. At 135mph you travel .0375 miles per second. That means I traveled about .3 to .4 miles before I saw the copper factoring in the fact that I was slowing down. By the way the coupe is very stable at 135 MPH.
w203 c230K 2002
The first time I hit the speed limiter I was not expecting anything, when I ran up on it I thought I broke something. I put the clutch in and slowed down. After I realized what was going on I settled down. It feels funny when it goes to work, your momentum can carry you over the 130 mark but the limiter will quickly pull you back.
Randy
Randy
randy, not that i want to, but is the speed limiter something you can remove w/ your computer software? (DAS?) is that something you considered doing?
w203 c230K 2002
Renntech is testing a software mod for the C230 Coupe. I'm not sure when it will be out but changing the Vmax is a normal function of a software mod.
Randy
Randy
