C240 SUSPENSION
Old Nov 26, 2012 | 04:49 PM
Pottie's Avatar
W163 & 203
C240 SUSPENSION
My 02 suspension almost give up and is time to replace those
Anyone can advise me if C55 suspension will fit direct to my C240 ?
I m in low budget so more like getting some used sport package or AMG set
Thank s
Old Nov 26, 2012 | 05:34 PM
TTR's Avatar
TTR
R129 SL500 & W140 S500
how'd your suspension give out? mine is creaking all the damn time and im not sure what the problem is. :S
Old Nov 26, 2012 | 05:45 PM
sammydragon3's Avatar
2005 c230 kompressor 2003 s500 94 wrangler
all depends on what your replacing..sport parts are gunna be more than non sport
creaking is metal on metal sound...so it could be your sway bar links or ball joints
Old Nov 26, 2012 | 07:01 PM
phister's Avatar
06 C230 SS 6spd
all w203 suspension can swap except for the 4matics
Old Nov 26, 2012 | 08:09 PM
TTR's Avatar
TTR
alright H&R sway bars here i come
Old Nov 27, 2012 | 10:56 AM
Pottie's Avatar
W163 & 203
I found used C55 suspension and wondering would be plug and play
and anyone hear or experience with this set up
Thank you
Old Nov 27, 2012 | 02:13 PM
glocati's Avatar
2016 GLE 350
Hey Pottie- It will fit. As Phi noted, W203 and w209 supension is interchangeable short of the 4-Matic. However, keep in mind that the front springs and struts are geared to the heavier CLK front and V-8 found in the 55. Higher springs rates for the additional weight. Good luck on it. Greg
Old Nov 27, 2012 | 05:21 PM
shadykilla's Avatar
'06 c230 Sport 6spd
If thats the case. Couldn't you swap everything but the springs and just get ur own springs?
Old Nov 27, 2012 | 05:46 PM
glocati's Avatar
2016 GLE 350
you sure could.
Old Nov 28, 2012 | 10:56 AM
TTR's Avatar
TTR
hmmmm, so oem or aftermarket sway bars? I guess if i'm putting sport springs I should put some aftermarket ones as well.
Old Nov 28, 2012 | 11:08 AM
shadykilla's Avatar
'06 c230 Sport 6spd
There is a guy on here in this section selling some sways. I don't have the cash right now for them. Check it out if your gonna look that route.
Old Nov 28, 2012 | 01:05 PM
phister's Avatar
06 C230 SS 6spd
get either C32 sways or get aftermarket. you can find c32 for pretty cheap, guy was selling his front and rear for less than 300.
Old Nov 28, 2012 | 01:28 PM
shadykilla's Avatar
'06 c230 Sport 6spd
Is there a diff between c32's and aftermarket that would make a big difference??
Old Nov 29, 2012 | 02:10 PM
Pottie's Avatar
W163 & 203
Thank you all for the input
At the moment I just got the used C55 suspension with spring and I m planning just to plug and play without removing front spring...if I cant stand then I might just replace with the original spring...
Unless someone here had this experience and would like advise which would be better...I dont do hard core drive but I love corner...
you sure could.
Old Nov 29, 2012 | 02:11 PM
Pottie's Avatar
W163 & 203
Thank you for the confirmation sir...
Old Nov 29, 2012 | 05:03 PM
phister's Avatar
06 C230 SS 6spd
i would have gone with the post facelift suspension (05+ SS). they actually are lower than the c32 and the springs rates are pretty stiff, actually stiffer than tein springs for our cars. you could have gotten a full SS suspension for around 200 for the struts and springs. some even pair the rear ss springs with front H&R springs to keep the rake our cars have.
Old Nov 29, 2012 | 06:09 PM
shadykilla's Avatar
'06 c230 Sport 6spd
Hey.. I got same as you. In terms of suspension for our cars. its really not worth replacing anything unless it brakes other then sway bars then right? And if something goes just stock replacements would be the way to go? Or is that really just for the springs? I like how it is stiff in the springs and theres no wheel gap.
