UNSURE ON THE RIGHT PAINT
Old Dec 29, 2012 | 12:09 PM
nickid's Avatar
LIMITED EDITION 2002 MERCEDES C 230 KOMPRESSOR DESIGNO SPORT
For some strange reason the bonnet on my yellow coupe is a different shade of yellow to the car and I wondered if the wrong paint was used if it has a new bonnet or its just faded?
The data card says 685U YELLOWSTONE?
but the car has 685 stamped on panel and that's SUNBURST YELLOW DB685?
Are they the same ?
Old Dec 29, 2012 | 05:50 PM
Glyn M Ruck's Avatar
Super Moderator
Different markets call the Benz colours different things. It's the code that matters when using paint from Glasurit, Spies Hecker, PPG or whoever.
Old Dec 29, 2012 | 07:28 PM
nickid's Avatar
That's just it. The data card says 658u and on the car it says 685 and the paint people are selling is DB658.
Old Dec 30, 2012 | 02:38 AM
Moviela's Avatar
685u probably refers to an old way the build cards specified paint. All three place codes ended with a u. The WIS shows "Farben alte Nummer: = 025U / MB-Nr. z.B. 0 025 nach WIS." 685 defines the color space for the paint. DB685 refers to the old name of Daimler AG which was known as Daimler-Benz AG. This keeps the formulation separate from other marques that use a 3 digit paint code.
Quite often cars damaged in transit are resprayed by a dealer, and the attention to making a fade to mask the minor differences in paint colour are skipped. If a formula other than the factory spray is used, it will quite often fade at a different rate than the original because each manufacturer closly guards the formula for the dyes and pigments used in tinting their base to match the manufacturer color swatch.
I am not sure how a car fades in the UK. My London office enjoys 300 minutes of sunshine per year.
Old Dec 30, 2012 | 05:11 AM
nickid's Avatar
Thank you very much for the info very interesting reading.
Will find a good painter that can do my bonnet again and also the arches where the rust is showing. Just hope It doesn't cost to much
Old Dec 30, 2012 | 11:18 AM
Super Moderator
I can assure you that with the new Glasurit waterbased base coat & nano clear the match will be perfect. The other premium companies are equally good but I have found Glasurit to be spot on with colour.
