CPS - "Crankshaft Position Sensor" Discussion Thread
Old Sep 23, 2008 | 07:04 PM
  #176
tonydr00's Avatar
2002 CLK 430
im still not done but here are some pics
the greeen thing u see above the cps is just a piece of sponge I used to stop antifreeze from leaking after i removed a hose.
be carefull with the hoses not to brake anything as you remove the big intake hose.
sorry i was not able to link the pics..
http://blastermix.com/photo/gallery/engine
http://blastermix.com/photo/gallery/location
http://blastermix.com/photo/gallery/intake-hose
http://blastermix.com/photo/gallery/cps-2008-09-23
Old Sep 23, 2008 | 07:15 PM
  #177
wblynch's Avatar
2008 c350 SG - 2004 c240 Wagon BS
Originally Posted by mleskovar
From another post: " If you remove the air intake pipe from the throttle body then you can reach from the center of the engine rather than the side which gives a bit more space. "
NOW he tells me...
Oh, and for those who didn't realize, you can press the button on your hood struts to release it and allow the hood to be raised to a vertical position. This will give you much more room to work.
Old Sep 23, 2008 | 10:17 PM
  #178
Mu9enx's Avatar
01' C32o
so will i need my VIN to get the correct CPS? i want to order it online but i think i might need to head to my dealership. it's WACK, my car wouldn't start today at Plati's German servince in pasadena. embarrassing and annoying!
Old Sep 23, 2008 | 11:25 PM
  #179
tonydr00's Avatar
2002 CLK 430
no you dont, all you need is the year and model... i went to my local carquest. same as the dealer
Old Sep 23, 2008 | 11:44 PM
  #180
Mu9enx's Avatar
01' C32o
okay that sounds great! thanks
Old Sep 24, 2008 | 12:03 AM
  #181
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
$20 saids this is a bosch part..
Old Sep 24, 2008 | 12:06 AM
  #182
Mu9enx's Avatar
01' C32o
we should have a tech day.. tomorrow! LOL.
Old Sep 24, 2008 | 12:08 AM
  #183
TemjinX2's Avatar
maybe a tech day in oct then go in another canyon run..*cough *cough canyon cruise.
Old Sep 24, 2008 | 04:29 AM
  #184
Saprissa's Avatar
From: San Diego, CA & San Jose, Costa Rica & Stuttgart, Germany
1959 220S / 1979 230 G / 2002 A210 AMG / 2003 C320 SC / 2004.5 C320 SS / 2005 ML350 SE / 2008 smart
Here are the pics:
Carlos
Saprissa@aol.com
Old Sep 24, 2008 | 06:01 AM
  #185
Glyn M Ruck's Avatar
Super Moderator
Originally Posted by wblynch
NOW he tells me...
Yes - the vertical hood makes a big difference
Old Sep 24, 2008 | 06:06 AM
  #186
Super Moderator
Mike - You could not resist - and you are probably right
Seems to be CPS month - Now every time I start my car I wonder ???? when's my turn? - perfect thusfar.
Old Sep 24, 2008 | 06:12 AM
  #187
Super Moderator
Do you have a pic of the sensor before fitting? I want to see what this pesky part looks like
Old Sep 24, 2008 | 01:07 PM
  #188
ArsnlKen's Avatar
02 w203,85 w123
Killer idea Glyn!
Originally Posted by Glyn M Ruck
+ 1 - & maybe it's time one of us put together a glossary of terms - i.e. Benz globaldy gook
+1...
Old Sep 24, 2008 | 01:15 PM
  #189
tonydr00's Avatar
2002 CLK 430
here you go
http://blastermix.com/photo/gallery/cpspic
Old Sep 24, 2008 | 02:59 PM
  #190
TemjinX2's Avatar
ok ok no more bosch atks. i know its gettting old..
yeah i'm starting to think if i should replace mine or not, just as preventative maintence.
thanks for the pics everyone has provided...it'll make good reference for the future.
Old Sep 24, 2008 | 06:19 PM
  #191
Mu9enx's Avatar
01' C32o
how do i get the cps out? what screw is holding it in? and what type of socket do i use to get it out? answer asap. in the process. TIA
Old Sep 24, 2008 | 06:25 PM
  #192
Mu9enx's Avatar
01' C32o
Old Sep 24, 2008 | 06:31 PM
  #193
TemjinX2's Avatar
the answer is here.
The CPS is on the flywheel flange behind the left (from driver's seat) cylinder head. It's pretty much on the centerline of the head.
It is held on by a small bolt and you'll need a 1/4" ratchet with a 14" long extension to reach it. I cant recall what size socket you'll need but I think it's about 8mm.
It's easiest to reach in behind the cylinder head and unclip the wiring lead. (There's no room for your hand AND the tool so you'll get angry and cuss out that car a few times before you're done)
Remove the screw and the CPS pulls straight up.
The new CPS goes in and you have to line it up by feel.
I put some paper over the screw into the socket to hold it snug. (...After I dropped the screw a couple of times and had to take off the splash shield and jack up the car to get under there and retrieve the screw)
When you're done, clip the wiring connector back on and you're done. All in all it took me less than 1 h
Old Sep 24, 2008 | 06:42 PM
  #194
Super Moderator
Originally Posted by Saprissa
Here are the pics:
Carlos
Saprissa@aol.com
What happened to the pics? Vista does not want to open MIME files
Old Sep 24, 2008 | 06:44 PM
  #195
Mu9enx's Avatar
01' C32o
the answer is here.
i did. i got everything but for some reason the 8mm doesnt fit. the 7mm fits but i cant get it out.
PS. SORRY MIKE
Old Sep 24, 2008 | 07:30 PM
  #196
wblynch's Avatar
PS. SORRY MIKE
The 8mm was only a faint recollection. It could just as well have been 7mm....
Old Sep 24, 2008 | 07:31 PM
  #197
TemjinX2's Avatar
PS. SORRY MIKE
its cool..i pick up some power steering fluid. long as the bolt fits, dont be afraid to put a little muscle into it. you can try using some wd-40 to loosen it up. If you know someone with a breaker bar, it'll be a lot easier since you can put more torque onto the bolt.
Old Sep 24, 2008 | 07:35 PM
  #198
Mu9enx's Avatar
01' C32o
****! lol, i think i might need a torx socket.. do you remember wblynch? was it a regular 6 side socket or a inverted torx? let me know!
lol, i did put a lotta force in it, so much my hands are all cut up. this is so annoying, haha.
Old Sep 24, 2008 | 07:36 PM
  #199
TemjinX2's Avatar
get a breaker bar...it'll make it a lot easier.
Old Sep 24, 2008 | 07:39 PM
  #200
Mu9enx's Avatar
01' C32o
as soon as my cousin gets home, i'll take her car to go pick up some stuff. speak of the devil she's here! brb dudes
You have already rated this thread Rating: Thread Rating: 6 votes, 4.33 average.
