'02 Coupe M111 baseline Dyno
Old Aug 3, 2003 | 06:32 PM
nukblazi's Avatar
Well, here are the results from the DynoJet. The shop used a exhaust probe to measure the A/F Ratio which is appearently wrong.
Max Run
Old Aug 3, 2003 | 06:33 PM
nukblazi's Avatar
Here are the numbers from the Max run.
Old Aug 3, 2003 | 06:36 PM
nukblazi's Avatar
and all four runs on the dyno on one graph... The shop owner and I were both surprised at how consistant each run was.
Old Aug 3, 2003 | 08:34 PM
midas888's Avatar
C230
Very cool, now I'm looking forward to the dynos with mods! Keep up the good work.
Old Aug 4, 2003 | 01:28 AM
nukblazi's Avatar
Thanks M-
Supposing all goes well tomorrow, the clutch will be in, and I will re-dyno Tuesday!
Old Aug 4, 2003 | 04:50 PM
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
Re: '02 Coupe M111 baseline Dyno
Max Run
Nukblazi-
Its not so much wrong as it is inaccurate. Sampling at the tailpipe looks at spent gas that has been through the cat- which will effect its reading. Typically a MBZ cat will shift up about one full point on a DynoJet- EG: 13.7 : 1 at the tailpipe is 12.7 : 1 pre cat. Sampling before the cat will remove any doubt-
Once you do your modifications you can sample at the tailpipe again- just be sure the readings are the same or slightly richer. You are looking at the differential between stock and mod at this point.
Old Aug 4, 2003 | 09:53 PM
nukblazi's Avatar
Thanks Brandon-
The install didn't fly today, the both shops were insanely busy... Tomorrow looks promising
