Oil Dipstick Location
The first picture is of the rear dipstick tube with cap. In the second one you can see the red dipstick in the lower left hand corner of (sorry for the fuzziness).
Also, if the one in the front is indeed for oil, why does my manual still say its in the rear?
Run the engine to operating temperature before extracting the oil.
Be sure to loosen the oil filter to let the oil run down into the sump. Replace only with a fleece (polyester) filter. Don't use a paper filter. Install filter up to the black line on the white pleats. It should be even with the base of the threaded portion of the cap. Use the o rings on the holder.
My idea is perhaps the tube was moved forward to allow more of the total volume of oil to be removed ahead of the axel pass through path.
I might be tempted to pull up the rest of the engine cover and looking for a rear tube. That said I would also carefully check that the tube indicated in the picture is not for power steering. I would go outside and look at my car, but it is 41 F, and I am a 70 degree guy!
I'm from the south which is why I never minded doing an old school oil change before but up here in Minnesota winters, I decided not to crawl around on a freezing garage floor and get an oil extractor.
