Timing Chain keeps jumping when rotated by hand.
C230K Sedan
![word](https://mbworld.org/forums/images/smilies/werd.gif)
2009 ML350, 2007 GL450, 1963 GMC, BMW 325i
That sounds a little odd.
Without knowing the extent of the work you've done I'll ask some dumb questions. Not trying to be a d!ck, just starting with the easy stuff.
Do you have the right chain? Did you compare the old one with the new one(depending on the install method)?
Did you replace the guides if they were removed or replaced?
Is the tensioner in place?
Everything has been tighented and torqued back down?
Cams are seated properly in the cam beds?
I remember having to move mine a little and push them in place to seat them down. If the rear part of one of the cams isn't seated properly it could lower the sprocket just a little giving a little slack.
What method did you use to feed the new chain in?
C230K Sedan
Can only instruct on a 271 engine. If both cam drive sprockets are tightend then should align correctly. Align all the timing marks and the tightest part of the chain should be the intake sprocket to the crank drive opposite the timing chain adjuster which should be checked and torqued down.
C230K Sedan
I got it.. I got it to rotate...the whole time it was just not lined up right. The markings on the cams was weiRd... I put everything back on and its all running now. My engine is finally rebuilt and working again...
