amg looking tail lights
how much did they charge you erik. can you post pics?
I will try to post some sort of pics tonight...
Erik
Erik
Thanks for the info. I allready called and asked about turn around time. I am local so they said half day to do my lamps. I asked if it took longer for out of state customers, and they replied only the time it takes to ship is added. Then I mentioned what Eric said about the turn around time and they actually remembered doing it for him, but stated in defence that the consumer mentioned that he was not in a hury because he purchased other lamps.
Pics will be up tonight...plus I can sell my tails if someone wants them...if not i am going to have them tinted and then resell them.
There is one tail on eBay right now, be careful, read the auction, its cracked..and they can't work with cracked lenses.
Erik
So did you have to send the whole assembly? or were you able to just take the lens off? Is this legal or does it vary by local law?
i know this sounds stupid but I have a few questions.
You send the whole assembly, not just the lense.
It is not legal in any state, however if you get a ticket depends on the cop. In my area they are very strict, so I had them "lightly smoked."
I had mine "lightly smoked" and it came out perfect. He smoked just the red area, leaving the clear part alone. They look dark compared to the OEM tails, but on their own they look like some tails from other manufacturers. They look like dark red, not black. I took pics, they look very dark in the pics, but in real life they are not that dark...give me a few mins i'll upload them.
Erik
www.erikcohen.com/lights/lights.htm
They aren't this dark in person, its the best I could do with the camera.
Erik
Thanks Erik for the pics.
I was wondering how it would look on a black car since mine is black as well... looks great. Now gonna call dealer and see how much they charge for a spare set of tail lights.
Erik
Vince has a Black Coupe with smoked tail lights that looks good. Should be a factory option in the darker colors
If you just do the inside one can would would be enough. I intend on doing the outside surface red only. Will leave the clear brake top portion alone. If you spray the smoke tint on the outside, remove the 4 nuts on each side. Apparently you also need to spray clear over the outside. Sounds like it can be done on one Saturday.
Also you can smoke the tail lenses yourselves. I bought the can of tint at a local Ricer shop, with tax $27. Sure beats the $120-150 that places who tint window charge for smoke tinting the tail lights.
1. Make sure the lenses are absolutely clean - use rubbing alcohol or something else to make sure.
2. Find a dust-free area. Hardest thing to do, yet makes the biggest difference.
A few dust particles can be compensated with additional clear coat as the clear coat will tend to smooth it all out and dust doesn't seem to show as well in the clear coat layers.
The clear coat is neccessary cause most of the smoke paint is not gloss.
Smoking the inside would do little on our cars, smoke the outside.
Also try it out on something first - the smoke dries much darker than it looks, find how many coats gives you the look you want by testing a small plastic object first (I did my side marker lenses as they will be replaced with clears anyways one day!).
Erik
Man...in NJ smoked lights would fail inspection without a doubt. We have rolling safety checks in a neighboring town...they issue tickets for everything from a blown bulb to a graduation tassle hanging from your rear view mirror. I got pulled over for a clear license plate cover...the cop said it obstructed the plate...but she liked the car, so she let me take the cover off right there at the roadside.
Erik
All this and waiting for my Renntech rear spoiler and Lorinser rear window spoiler, all this and I keep getting the dreaded Check Engine light for the THIRD time!!!! At 4300 miles they replaced the fuel pump. Came back on last Friday at 5000 miles, it went away so I cancelled the appointment.
No sooner cancelled the service appointment when the Check Engine light came on again and has staid on the last two days.
Next appointment is NEXT Friday so I have a long wait.
