Parking Lamp Help!
Old Jan 21, 2013 | 08:00 PM
230c's Avatar
2005 C230 Kompressor
Unhappy Parking Lamp Help!
First I had condensation inside my front passenger side headlight, so I popped off the black protective caps on the parking lamp and high beam lights. I feelt around a little bit and then left it for a while. I can back the next day and all the condensation was gone but my parking lamp doesn't work. The high beam still works but I don't know how to fix the Parkin lamp now! Have I done bad damage? Pulled a wire? Blew a fuse?
Old Jan 21, 2013 | 08:01 PM
230c's Avatar
I have a 2005 C230 Kompressor
Old Jan 21, 2013 | 08:38 PM
phister's Avatar
06 C230 SS 6spd
Check the fuse. Do you have the lamp bulb out warning on your dash display?
Old Jan 21, 2013 | 08:56 PM
230c's Avatar
Yes I have a warnin light that says "Front right Parkin lamp out"
Old Jan 21, 2013 | 08:58 PM
230c's Avatar
Warning* parking*
Old Jan 21, 2013 | 11:07 PM
Moviela's Avatar
There is no fuse associated with the parking lamps. The front SAM controls them electronically. The lamp is a wedge base where the contacts are wires that extend outside the lamp. The wires sometimes don't make a good connection with the socket.
Clean the lamp terminals with alcohol and try again. Wiggle the lamp in the socket to see if it illuminates. Take the lamp out, turn it around and plug it back in. You could just change it. It is a 5W bulb that only cost a couple of bucks.
