smart key issues
Old Jan 28, 2013 | 11:13 AM
dasbesten's Avatar
2004 C230
Unhappy smart key issues
My 2004 C230 smartkeys only lock/unlock the car when held close to the doorhandle. Both work the same, not a battery issue. It appears the car is not receiving the radio signal. Any one have an idea what the trouble is?
Old Jan 28, 2013 | 02:34 PM
Glyn M Ruck's Avatar
Super Moderator
There are numerous threads in this regard. Your RF is down & you are depending on the IR window in the door handle.
The reasons can be many & you will find a ton of advice here.
Mainly: Due to the RF antenna being mounted in the rear screen
~ Fitment of a metallic tint - remove metallic tint
~ Antenna wires being cut when fitting a tint
~ Sticky connector pad coming unstuck at centre top of rear screen
~ Water from the tint shorting the antenna
~ Blown antenna amplifier
~ Rear screen failure. Break in traces in the glass
~ Antenna unplugged between rear & radio
Good luck!
Old Aug 13, 2013 | 11:29 PM
cmh1991's Avatar
'03 C240 and '05 C230
Good luck!
I just got my car retinted and noticed the smartkey not working unless the key is pressed at the drivers door
Old Nov 21, 2013 | 06:53 PM
Tdj131's Avatar
2007 CLK350 convertible
Wher is the ant. Conn. For the rear widow . 2007 clk 350 conv.
