INEXPENSIVE DIY ADJUSTABLE REAR CAMBER ARMS
Old Jan 31, 2013 | 11:09 AM
hanknum's Avatar
'02 C320 Wagon, '78 308 GTS, '06 Highlander Hybrid
Just remembered to post this...
Here's a link on how to order up some ajustable camber arms. This ends up being much cheaper than anything else out there and are good quality. I've installed these on mine and works great...something like $70.
http://www.google.com/url?sa=t&rct=j...41642243,d.cGE
I'll try and post up some pix and more info here soon.
Old Jan 31, 2013 | 12:29 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Thanks for sharing! These look awesome. Do you by chance have a DIY for making your own front sway bar endlinks? :x
Old Jan 31, 2013 | 12:44 PM
phister's Avatar
06 C230 SS 6spd
End links should be the same but you just have to measure your length. I'm fixing to order the energy suspension ones next week. They run about 80 for the pair
Old Jan 31, 2013 | 01:37 PM
TruTaing's Avatar
Moderator Alumni
w203 m112
Do post the info when you get it all sorted out!
Old Feb 1, 2013 | 03:46 PM
hanknum's Avatar
Sorry no info on endlinks, but here are some pix of the camber arm install...
Attached Thumbnails INEXPENSIVE DIY ADJUSTABLE REAR CAMBER ARMS-imgp0050.jpg   INEXPENSIVE DIY ADJUSTABLE REAR CAMBER ARMS-imgp0053.jpg   INEXPENSIVE DIY ADJUSTABLE REAR CAMBER ARMS-imgp0054.jpg
Old Feb 2, 2013 | 01:24 AM
glocati's Avatar
2016 GLE 350
Nice Info, Henry. Looks like some decent adjustment range. Did you get yours from Speedway?
You threw some new rear rotors on as well?
Hope all is good in your world.
Old Feb 2, 2013 | 02:07 AM
hanknum's Avatar
Hey Greg,
Yeah, I think the min. center to center was around 11.5" and I've got them set around 11.75", but they can probably extend to around 13". Good quality and you can't beat the price. Got them from Speedway for something like $75 delivered. I went ahead and replaced all rotors (fronts were below the min. th.) and Akebono pads all 'round. The new pads and rotors had zero bite initially, but once they were bedded in some, they feel pretty good.
Everything good here, say hi to Jen, Grant, and ??? for me.
Old Feb 3, 2013 | 10:38 AM
glocati's Avatar
2016 GLE 350
Originally Posted by hanknum
Hey Greg,
Everything good say hi to Jen, Grant, and ??? for me.
That's great on the arms. I need to do a set. Just did new rear tires....Sending you a PM.
Old May 10, 2013 | 11:58 AM
thegame11's Avatar
1997 C280 Sport
how are the arms holding up. Have you had any issues with them. Are aluminum sleeves strong enough for everyday use. What worries me is that the aluminum might no be strong enough and brake off.
Old May 10, 2013 | 02:34 PM
hcoronado's Avatar
2021 GLC300 4Matic
I've had mine for about 6 months and so far so good - no complaints. Just use some high performance grease when you get to assemble the arms.
Old May 10, 2013 | 03:49 PM
hanknum's Avatar
No issues at all. I think all the others are also aluminum. No need to worry though, these do not carry any load. They mostly just position the wheel.
Old May 11, 2013 | 08:30 PM
thegame11's Avatar
1997 C280 Sport
Thanks for the feed back this is definitely on my list then.
Old Jun 27, 2013 | 03:35 PM
C230Kreepin''s Avatar
04' C230K
When you got the sleeves what length did you go with?
Old Sep 11, 2013 | 02:20 AM
Black_Mercedes's Avatar
C63 P31, C320
Could you please post all information so i can order a set for myself.
Thank you
Old Sep 29, 2013 | 10:20 PM
Pezee's Avatar
2005 c230 Kompressor
just ordered mine 130$ shipped to hawaii
Old Oct 1, 2013 | 11:03 AM
Stuka Bomber's Avatar
2007 c280
Not sure if it's the same thing since I can't view the links or pics at work through the firewall but I suspect you can pickup these bars at your local tractor supply for $13 each. I've been using the huge ones as panhard bars for my low riders for years. Zero issues.
Ie: 67 Chevy c10 on bags
55 Plymouth belvedere on bags
Old Oct 1, 2013 | 03:56 PM
hanknum's Avatar
9"
Old Oct 2, 2013 | 08:50 AM
2007 c280
What exactly is the purpose of these? Allows for the correct range of camber on lowered cars but is this for coilovered cars? Or just springs requires this?
Thanks guys.
Old Nov 24, 2013 | 11:58 AM
danfranjr's Avatar
W204
Is this applicable to W204? I prolly need to give more negative settings to it.
Need help as my rear rims are rubbing my fender due to offset issue (ET 40). Running on 265/30/19 tire series.
Any replies would be much appreciated.
Thanks.
Old Nov 24, 2013 | 01:04 PM
Boom vang's Avatar
2019 C300 Wagon; '75 Triumph TR6; previous: 2004 C230 6spd sold after 17 years of driving
I like the idea of these for my car since I lowered it, however:
I wonder what is the durability of these?
because,
Alum and steel hardware together in a winter environment with salt and water etc = galvanic corrosion which eventually will eat the threads giving failure. In a warm climate where you don't encounter salt and salt water spray on the roads there is no worries
Old Nov 24, 2013 | 06:59 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
K-MAC Adjustment Kits
K-MAC
1. Manufacturer of Wheel alignment products and also suspension bushings
2. 90% of todays vehicles have no alignment facility because of cost cutting and speed of assembly lines to provide adjustment to resolve premature costly, inner edge tirewear, improve traction and breaking response.
3. 2 Billion autos and alignment companies merely adjust TOE (turning the wheels In or Out which only alters wear position from the edge to the centre as it now skids down the highway.
4. K-MAC manufactures the worlds largest range AUDI to VOLVO - being the longest established with more experience.
5. "Bushings" (the first vehicle item to fail) - huge OEM industry in supplying replaced bushings.
6. K-MAC are superior to OEM designs
Old Nov 25, 2013 | 12:37 AM
danfranjr's Avatar
W204
Browsing through days and nights but to no avail of solution to have W204 rear clearance from fender.
Old Dec 31, 2013 | 04:36 PM
syfi's Avatar
2005 Crossfire Limited N/A & 2005 Crossfire SRT6
Originally Posted by Boom vang
I like the idea of these for my car since I lowered it, however: I wonder what is the durability of these? because,
Here's a link to my post over on the Crossfire Forums for the set that works for us. These use a DOM swedged steel tube in place of the aluminum. Much more heavy duty and the setup has been race tested in the World Of Outlaws. More then adequate for our needs. I've had these on for nearly a year and tires are wearing perfectly. And I'm running 2 sizes over OEM (275/35-19)
http://www.crossfireforum.org/forum/...tml#post712854
Old Jan 1, 2014 | 05:56 PM
2007 c280
For those of us new to MB, the crossfire is built on the MB w203 frame correct? So that shopping list should be identical to what our cars require right?
How about 4matics? Are the camber arms the same Awd and 2wd?
Old Jan 3, 2014 | 01:52 AM
syfi's Avatar
XFires are built on the r170 frame. I'd say that if you can use the ones discussed in this post, then these will fit also. Only difference is the use of steel tube instead of aluminum. Just measure the size of your OEM arms. I believe our standard length between ends is 11.5 - 11.75 inches. That's why the use of 9" tube. 1/2" dia. bolts fit through each end. As long as no sway bars in the way and you have a straight shot between ends, these should work fine.
