error code P0455 EVAPORATIVE EMISSION LEAK GROSS LEAK/NO FLOW for Merz C240 2002 mod
Old Feb 7, 2013 | 06:05 PM
jaroms10's Avatar
Merz C240 2002-2003
Smile error code P0455 EVAPORATIVE EMISSION LEAK GROSS LEAK/NO FLOW for Merz C240 2002 mod
error code P0455 EVAPORATIVE EMISSION LEAK GROSS LEAK/NO FLOW for Merz C240 2002 model
I have another error messages here regarding my C240 model 2002
* PO300 RANDOM MISFIRE DETECTED
* PO305 CYLINDER 5 MISFIRE
* PO455 Evaporative Emission Leak gross leak/no flow
please help what and how to fix this
thanks
Old Mar 10, 2013 | 07:52 AM
bairdrl's Avatar
SLK 230
I have the same error codes
If I find out what the answer is - I will send you a post.
Old Mar 10, 2013 | 10:37 AM
Glyn M Ruck's Avatar
Super Moderator
You need to check everything from the fuel cap to the carbon cannister to a failed purge valve. See diagram of EECS.
On a car your age if the plugs are good the likely cause of a misfire is plug leads. Replace them. After that could be a coil pack. Mark & swap coil packs around & see if misfire changes cylinder.
Good luck!
https://mbworld.org/forums/attachmen...unction-1-.pdf
Old Mar 11, 2013 | 04:34 PM
jaroms10's Avatar
Merz C240 2002-2003
codes
Thanks you for this information
I can use this to check the problems
