Engine Upgrades for less than Crazy Mechanics Charge.
Old Feb 11, 2013 | 07:31 AM
Sniperwoods's Avatar
C200 Kompressor
Angry Engine Upgrades for less than Crazy Mechanics Charge.
Hey guys, been lurking for a while.... :p
I have a few questions if anyone can give opinions on that would be great.
I recently took my Merc to a mechanics to get serviced. When I picked it up they said I would need to replace the Head Gasket as some coolant was slowly leaking into the engine. (fair enough) But then he said its going to cost you $2300AUD.....
That is an outrageous amount of money to just change the Head Gasket.
Anyway so my questions are, what sort of Head/Engine Block modifications should I get done (By someone else) That will both fix the problem and also improve the performance. The engine is only the 1.8L with supercharger. I was thinking of doing a pully Upgrade down the track.
Anyway guys Suggest away.
Also HI everyone
Old Feb 11, 2013 | 06:20 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Actually not a bad price, especially consider AU.
Here in the states, my indy recently did a head gasket on an m111
and he said it took 2 day, ie 16 hours, + parts.
His rate is 100 hr US. The dealer is 175 or more.
So...that's about right.
I would do the thermostat and water pump while yer at it.
I'd get an oil analysis 1st though.
Old Feb 11, 2013 | 09:50 PM
edgarinho10's Avatar
2013 UFO
At that price you might as well just get a motor swap if you have a high mileage vehicle
Old Feb 11, 2013 | 09:55 PM
C200 Kompressor
Yeah that's what I was looking into too. My engine as 140,000km (86,000miles), there was an engine for $1200AUD with only 90,00km (55,000miles)
How much typically would it cost to put in? $1500?
Old Feb 11, 2013 | 10:06 PM
2013 UFO
Ha. That's not high mileage. If anything just look around and see if you can get a better quote.
Old Feb 11, 2013 | 10:07 PM
2013 UFO
What exactly did he do that took 16 hours?
Old Feb 12, 2013 | 06:08 AM
torake's Avatar
C180 Kompressor Wagon
If you are taking the head off, check and possiblpy have it machined flat before replacing. Also, change your timing chain and slides.
There's nothing there to do in terms of performance, especially not if on a budget. Pulley kit, software and exhaust header are the first steps on M271.
